PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. gdasbadvava
    gdasbadvava Newbie
    what is a pot,i thing if i use a bsel mod to underclock cpu it would work does there is a mod to downclock a socket p or overvolt cpu when eist is stoped
  2. tilleroftheearth
  3. gdasbadvava
    gdasbadvava Newbie
    at last i wire mod vdi4 to vss and cpu get unlock at full multiplier with speedstep enable at 3200mhz
    CPU-Z Validator 4.0
    cdoublejj likes this.
  4. cdoublejj
    cdoublejj Notebook Deity
    gdasbadvava likes this.
  5. gdasbadvava
    gdasbadvava Newbie
    i bsel mod this cpu for 333mhz bus speed but computer dont turn on with mod i think this is for memory limit does i can change memory timing and dram frequency for bsel mod to 333mhz by cpu or pll moding
  6. Qing Dao
    Qing Dao Notebook Deity
    Did you try 333Mhz with a 6x multiplier? 333Mhz fsb with the stock normal multiplier is too high for that CPU. You also might need to slightly overvolt the northbridge.
  7. rickdekard
    rickdekard Notebook Enthusiast
    Hi,
    Another overclocked laptop, the Dell Precision M6400.
    I just put a little wire one the socket to put BSEL2 to VCC. Fsb Goes from 266 to 333 Mhz and the P8700 goes from 2,53Ghz to 3,3Ghz.
    It is a jump of 20% in performance.
    The INTEL Chipset does not see the BSEL MOD and don't lock the processor multiplier to 6x....I'm Lucky.
    Will try next week end with my other M6400 with QX9300. If it works, It could be a 3,3Ghz QX9300 laptop, quite good.
    User32, alexhawker and capitankasar like this.
  8. Qing Dao
    The QX9300 already has an unlocked multiplier. There is no reason to try to overclock it via the FSB. You can determine the optimal multiplier and voltage using throttlestop. Then you can pin mod the multiplier and voltage to get it to work just how you want it to.
  9. rickdekard
    Yes I know but what a overall performance jump when you boost the FSB!
    Here is the proof with the QX9300 @4Ghz:
    CPU-Z Validator 4.0
  10. Qing Dao
    Good work on your overclock.
