PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. triturbo
    Thank you for your input. That's really sad news :( I paid €145 for those and it's my most expensive upgrade. Probably I'll just call it a day. I saw your other post, if it turns out to be true, then I'll be able to make FSLx+BSEL mod, and I wont need to flash my RAM, as it would switch to 400MHz table.
    EDIT: Yep, protected. Damn hynix.
  2. dadik
    dadik Notebook Enthusiast
    Hello, guys
    Abo didnt answer, so I am still trying to figure out how to make setfsb work, first of all when I try to alter FSB via setting bits of register 14 , laptop reboots with new FSB instead changing it "on the fly". Does somebody knows why?
    Second problem, If I read correctly, PM45 cant boot up on 333, right ? Cause PM45 support up to 1066, so even if my P8400 could handle 333mhz without voltage increase, it wont boot up anyway.
    I can see that there was similiar thread long time ago
    http://forum.notebookreview.com/har...-upgrades/394367-overclocking-p8400-pm45.html
  3. User Retired 2
    I did a 266->333Mhz FSLx PLL pinmodded on a P9400-2.4 Dell E4300 after which it booted at 3.0Ghz. Increased it further to 3.16Ghz by running a dual-IDA Throttlestop configuration.
    The system needed a VID voltage regulator mod to increase top end voltage at highest multiplier. Samsung DDR3 RAM worked without problem but Hynix would give BSODs. See details. The P9300-2.26 version likely would have not needed any VID voltage regulator mods.
  4. dadik
    Thanks for info Nando :)
    I think that VID mod is inevitable, I wont FSLx or any soldering, TME mod was just enough for my shaky hands :D so I really like to do it software way now. Btw link on those datasheets is very usefull for me, I know its not my 513v but some reserved bits are clarified now (I may not fit on mine pll but worth a try) I am still trying to figure out whats causing laptop reboot after FSB change, maybe watchdog ? I am really desperate :/
  5. antyfr
    antyfr Newbie
    i all i am new (and french)
    i need some help, i have an hp hdx x16 with rtm875n-606
    i have pin mod 11 but i dont know where is bit 6 in offset 09h to read tme_readback(and where is bit 1,2,3...)
    thanks
  6. User Retired 2
    Your offset 9 bit 6 is zero, meaning TME is unlocked. Pls follow details in Re: RTM875t-606( Info gathering and OCing) to try to overclock the system and report your results.
  7. antyfr
    antyfr Newbie
    tanks you very much nando4
  8. dadik
    Hello, so finally I managed to overlock via TME unlock my P8400@3Ghz (333x9 1,2V)
    problem was that my samsung module cant handle 1333 with 1066 timings(Micron can :) ). I still dont know why after FSB altering my laptop reboots with new frequencies.
    What do you think guys should I get better modules, do volt mod and try go for 400 ?
    And one more question Since FSB increase rebooting is there way to apply this setting before entering OS ?
    by the way thanks, without help and this forum I couldnt do it!!
    here is screenshot:
    Image-Share - image-jpg-1437-177
    //edit: aww solo samsung works too, some kind of conflict :/
    //edit2:
    Bricked that samsung modul, first of all I decreased minimal CAS latencies supported to 8 from 7. It wasnt enough so I decided to drop it to 9 which was rly bad idea, I suppose I can restore modul booting up at 333Mhz.
    BTW I used SPD tool but byte 14,15 (http://en.wikipedia.org/wiki/Serial_Presence_Detect)
  9. Javier Gusfraba
    Javier Gusfraba Notebook Enthusiast
    First off ,thanks Nando for the links
    the problem is the more info i read the more questions i have.
    my pll is slg8lp554v and my processor is a t7300 @ 200 mhz
    reading over this thread it seems pulling pin 45 to ground via a 5k resistor would achieve 266 mhz operation?
    The problem with that for me is pin 45 ..the trace on motherboard dives through board like 1/32 (random number..its close) of an inch away from
    the pll chip. and im really not to keen on cutting the traces if there is a workaround...looking at your pll mod on your E4300 i see you get 333 mhz from 266 with alot safer approach imo . would a similar type of mod work for 200 - 266 operation? or am i way off base here?
    image shack made the quality degrade significantly but here is the shot
    my pll
    ImageShack Album - 2 images
  10. dadik
    Hello, in you case 200>266 is 010>000 so u need FS_b pull to 0(10k resistor to gnd) which is pin 45.
    266 to 333 000>100 FS_c pull up. But you starting at 200 so both mods, and volt mod for CPU. If u want 333 mhz I recommend you to get PXXXX with 266 default.
    I hope it helped.
