PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. MotoVlad
    MotoVlad Newbie
    I'm having difficulty with his check, on my laptop bus speed does not rise above 153 MHz (154 instant crash), I changed the RAM, and gave higher voltage cpu - still freezes momentarily, at 152 completely stable. What could it be?
    Keep me elaboration pll file for the program setpll. Please accomplish your goal, to how much you were able to overclock this pll. pll file is now in beta testing
    How to use the program's setpll described in this forum
    Download PLL file SLG8SP585
    I am sorry, the last file has been corrupted. Please download the working file
  2. rickdekard
    rickdekard Notebook Enthusiast
    I have done it!
    My M1730 has got a motherboard with SLG8LP550 clock generator.
    I cut contact on pin 45 and let it in the air, no need to ground it and it works!
    At the moment:
    M1730 with X9100 at 4GHZ (15x266) and 9800M GTX SLI 775/1650/940
  3. Cleonard
    Cleonard Notebook Consultant
    Just a quick note to alert you that voting for the NBR Amazing Content Contest comes to a close on February 17th! Also, we added an additional prize for the thread that comes in 2nd place in the member voting, so get out and vote for this thread! Rally your supporters and storm the voting both while there's still time!
  4. rickdekard
    Here is the proof.
  5. mnemonik
    mnemonik Newbie
    Hi, sorry for my bed english
    please, i have GM45 and T5870 core 2 2GHZ 800mhz
    i used BSEL mod in first page, wire B23 and B24 on socket P.
    now is 1066 MHZ but CPU multiplier is blocked to 6X
    total 1596 MHZ
    how i can unlock multiplier
    Bye bye
  6. whitrzac
    whitrzac The orange end is cold...
    How do I get setPLL to run on startup? I tried messing with the auto folders/files but I get an error when I try to run it...
  7. MotoVlad
    MotoVlad Newbie
  8. vladichimescu
    vladichimescu Notebook Enthusiast
  9. dadik
    dadik Notebook Enthusiast
    Hello,
    first of all I would like to thank you for doing gr8 job here :)
    I need advice(s). Got HP dv6-1419eo in default T4300 + 4GB DDR3 1333MHz today I switched CPU for P8400 with 266x8,5=2.26GHz
    PLL is SLG8SP513V TME is enabled if I set PCI2 bit 2 to zero notebook wont freeze.
    Image-Share - image-jpg-1322-252
    other side of the MB is clear, there are instructions how to modd this pll but not HP which makes difference, R 122/R1424 isnt around the chip
    My goal is FSB 333Mhz. which according to datasheet is pin 5 seting to 1 and it seems littlebit complicated. So Guys is there any possibily to get FSB 333Mhz ?
    I hope someone can help me, thanks in advance.
    BTW: with new CPU I am getting EIST, and it seems that all links for modded BIOS F.43 are dead :(( If some1 know about woking link please contact me.
    similiar or same name : HP_DV6-1xxx_DV7-2xxx_INTEL_sp51619_3623F43_no_whitelist_more_optio ns.zip
  10. mbze430
    mbze430 Notebook Enthusiast
    I was given a L455D-S5976 that I want to overclock. the PLL on the motherboard is a SLG8SP626V. I was following a thread about SETPLL, but it was kind of old and all the documents for different PLL has "disappeared".
    Anyone got or can help me OC this laptop with the SLG8SP626V PLL?
    TIA
