Please Recommend A Cooling Pad For Gaming
Discussion in 'Gaming (Software and Graphics Cards)' started by ronferri, Nov 10, 2017.
  1. JRE84
    JRE84 Notebook Consultant
    oh yeah i just remembered i removed the bottom panel....with the panel on i was only seeing a 5c differance....with the panel removed yeah as outrageous as it sounds 20c maybe more
  2. Mobius 1
    Mobius 1 M$ BotNet 10
    If you have the SF-19 then you should be good without modding.
    U3 is more budget friendly and opens up modding possibilities.
  3. ronferri
    ronferri Notebook Evangelist
    is there a place where I can buy a modded U3 cooling pad with bigger fans, antidust magnets, and more volts?
  4. hmscott
    Yup, I had 2 of them for my Asus W90vp I would run when doing long batch jobs, but they weren't practical for every day use, too noisy.
    They were fairly large, I tried the smaller ones and didn't help enough, these look just like the ones I had, and I think it's the same manufacturer:
    OPOLAR Laptop Fan with Temperature Display and Cooling Pads
    https://www.amazon.com/dp/B01E3Q7FS...1A&pd_rd_i=B01E3Q7FS6&hsa_cr_id=9546078830901
    As I recall the 2 of them dropped the GPU's and CPU temps quite a bit. I sold them with the laptop.
    As you can see by the noise reading, these new ones are still noisy:
    And, pretty big too:
    Nice shrouds to direct and force the air from the vent effectively:
    And I recall the temperature reduction claims at the time were met, and even better with 2 of them running, one on each side:
    The one's I had didn't have temperature readout, but I think they were $10 less than these, of course that was back in 2009.
    I haven't bought any since because the cooling has been good enough in the Asus and MSI laptops I have had, and even if they help - they were just too noisy :)
    1,700+ positive reviews though, so someone likes them :)
    https://www.amazon.com/LC05-Cooling...show_all_top?ie=UTF8&reviewerType=all_reviews
