please help my fan keeps turning on and off every 2 to 3 minutes?
Discussion in 'HP' started by ahmednagy5, Jan 12, 2007.
  1. ahmednagy5
    ahmednagy5 Notebook Enthusiast
    i just had my dv 6000 a month ago,i noticed that CPU fan keeps cycling on and of every 2 3 minute although CPU tempraturee doesn exceed 36 C when idle so is this normal ,i duuno what to do.anyone has the same .
    PS :i have made the usb trick to cut down the buzzing sound from that comes from the processor.
    Specs
    Dv 6183 ea
    1.83 core 2 duo
    100 GB HDD
    1 GB ram
    G force go 7400 256MB
  2. vassil_98
    vassil_98 Notebook Deity
    Go here, install the latest BIOS and see if that changes anything. HP has to issue a new BIOS in order to change the temperature levels at which the fan starts. There's nothing wrong with your laptop; this is just the way the fan is programmed to work. I don't think the USB thing messes with the fan. It won't hurt to try restoring the usb power settings, however.
    If not, get Speedfan or some other program like that to control your fan manually. There's no guarantee that it will work, though.
