Please help me in my decision of buying between two gaming laptops
Discussion in 'What Notebook Should I Buy?' started by notebook_review, Jan 20, 2019.
  1. notebook_review
    notebook_review Newbie
    Hi all!
    I would please you to tell me which of these two gaming laptops is better,and especially has better cooling solution
    HP OMEN 17.3", i7-8750H, 16GB/256GB SSD 1TB HDD, GTX1070 (8GB4RF81EA)
    and
    ASUS GL703GS-E5011 - Intel Core i7-8750H (2.2 GHz, 9M Cache, up to 4.1 GHz), 16GB DDR4 (1 mem.slot free), 256GB PCIE G3X4 SSD + 1TB 540
    Thanks to all in advance.
  2. Danishblunt
    Danishblunt Guest
    I would go with the Asus because of superior panel.
  3. notebook_review
    Thank you!
    What about the cooling?
    Which of them two has better cooling?
  4. Blacky
    Blacky Notebook Prophet
    Both laptops are pretty bad when it comes to cooling.
    The Omen 17 has better cooling but has a poor fans profile. I suppose if they fix the fan profiles through some BIOS updated, which they have been trying to do, it will a pretty good laptop.
    The Asus has a better display, but has terrible cooling as far as I know and often throttles and overheats. Asus also has some poor quality control on its units.
    If you are buying from the US, Asus has a rather poor warranty and customer support there.
  5. notebook_review
    Thank you very much!
    Could the fans be controlled with good setting of the software called SpeedFan?
  6. Rushmeplsnow
    Rushmeplsnow Newbie
    I would skip most of Asus gaming laptops due to overheating/throttle.i own a omen 17 with gtx 1070 and a 7700 hq. On stock it ran even on 90-95 degrees i undervolted and repasted and it goes only to 75-80 now.i bet the 8750 h runs hotter.
    notebook_review likes this.
  7. Blacky
    I am not sure, never heard of this software, although I am not surprised it exists. You may have to ask those who made SpeedFan. If it does work, let me know.
  8. notebook_review
    It surely works for both laptops and desktops!
    Here you are a guide for how to set up SpeedFan:
    and the site of the creators: http://www.almico.com/speedfan.php
    Please try it,and tell me if it works.
  9. Blacky
    I am sure it works for desktops, not sure for laptops. It might depend on the laptop model.
    Papusan likes this.
  10. notebook_review
    What laptop model do you have?
