Please give me a working GPU monitor gadget on 5870
Discussion in 'ASUS Gaming Notebook Forum' started by polish_pat, Dec 3, 2010.
  1. polish_pat
    polish_pat Notebook Consultant
    Does anyboby know a gadget that allows me to monitor my GPU?? like temps and clock speeds??? there are some but they all use rivatuner which has not been updated to work on 5870
    thanks
  2. KuroLionheart
    KuroLionheart Notebook Deity
  3. polish_pat
    thanks bro yo rock!!! do you know if GPU load and fan speed are supported by an 5870!!
  4. mblue0122
    mblue0122 Newbie
    MSI afterburner works too.
  5. polish_pat
    thanks...i just installed it, looks great but is there a sidebar gadget that comes with that??? that mostly what im looking for
  6. JOSEA
    JOSEA NONE
    Pat I am using HWINFO32 gadget (hw32_362). It is easy to configure, but you must have the program running to use the gadget.
  7. H-street
    H-street Notebook Guru
    gpu-z doesn't work?
  8. puterg33k
    puterg33k Notebook Consultant
    Wow awesome I was looking for one as well, but didn't think to post. The HWINFO32 one is great, however; looks like crap. I haven't seen the one that KuroLionheart posted, I'll check it out tonight.
  9. daranik
    daranik Notebook Deity
    I use AMD clock tool to monitor GPU temps, I know not the best but it gives me an idea and I use HWinfo for more in depth monitoring.
  10. macmaniacal
    macmaniacal Newbie
