please can u help ..its easy problem
Discussion in 'Windows OS and Software' started by ghoul, Jun 26, 2004.
  1. ghoul
    ghoul Newbie
    i have laptop kind notebook ..20G....SPEED(2600HZ).......
    264(RAM)........PANTIUM 4........
    ....my problem that was ..one of my friend ..he want to charge the computer but he made it Opposite(i mean the wire )...the problem now it doesnot work .cuz no power is there and cant charge ... to do my work ..please it will be very kindly if u told me what i can do with ...
    that .. i can change the wire ...or what .. i dont know what i can do just tell me .. [:(]
    there is never wrong time to do something right
  2. bootleg2go
    bootleg2go Notebook Deity NBR Reviewer
    If you plugged in the charger that came with the notebook, there is no way to hook it up backwards(opposite) as it only plugs in one way. If your friend just connected wires from a regular power supply to the notebook, chances are that the battery charging circuit in the notebook burned out, maybe even more. You will probably need to send it in for repair.
    Jack
    The color of justice in america is green.
    http://pbase.com/joneill
  3. ghoul
    ghoul Newbie
    thank you so much brother for helping me ..........
    and i wish u a good life .........and thx for all they are doing in this forums
