Playing Games Installed vs Not Installed
Discussion in 'Gaming (Software and Graphics Cards)' started by Valour549, Nov 11, 2014.
  1. Valour549
    Valour549 Notebook Guru
    If u play a game where u simply copy an entire folder over and launch the game from there, compared to properly installing the game on ur laptop, is there any difference at all in terms of launch speed or performance?
    In particular I'm talking about on an SSD. I feel like pasting a folder in an SSD and running from there won't be as fast as properly installing a program in ur SSD. Might be wrong though.
    Thanks in advance for any thoughts or expertise on this matter.
  2. fatboyslimerr
    fatboyslimerr Alienware M15x Fanatic
    Sounds good but might there be registry conflicts?
  3. Redbeard
    Redbeard Notebook Consultant
  4. D2 Ultima
    D2 Ultima Livestreaming Master
    Most new games require actual installation. Some games don't; the launch speed doesn't change too much. Especially on a SSD; at worst it'd be like 1/4 second or something.
  5. Apollo13
    Apollo13 100% 16:10 Screens
    It depends on the game. If the game looks up files in the registry, it may well fail to run without a proper installation. If it runs everything locally, then there shouldn't be any speed difference, since it's just looking in its folder, anyway.
  6. HTWingNut
    HTWingNut Potato
    Most games rely on registry entries and also sometimes on tertiary programs installed/running (i.e Punkbuster, .Net, etc) that would come with the installation process. As far as performance, it wouldn't really matter. As noted, Starcraft 2 doesn't care, a lot of people run it off their USB thumb drives.
  7. saturnotaku
    Fixed that for you.
    If you're running a game from Steam, where you put the game doesn't make a difference since it's downloading all the files it needs. Where what you want to do wouldn't work so well is with games on physical media due to the aforementioned registry conflicts.
    D2 Ultima likes this.
  8. maxheap
    maxheap caparison horus :)
    Steam games can be copy-pasted because Steam has its own registry entries after installation and the copy-pasted game communicates through Steam.
  9. James D
    James D Notebook Prophet
    I alway do it... keep games on drive D and sometimes reinstall OS on drive C. Game will create registry entries when first launched.
    But my Documents folder is on drive E so I never delete it when install OS.
    The only game which didn't run was Halo so I keep extracted registerstrings for it.
