pictures with built in camera
Discussion in 'VAIO / Sony' started by TTran008, Apr 29, 2006.
  1. TTran008
    TTran008 Notebook Enthusiast
    how do you take still images with the webcam on the sz? i open up the camera and i can see the live stream but i can't take it as a pic. any help?
  2. SkrunchaMunch
    SkrunchaMunch Notebook Enthusiast
    Hi,
    Usually, you can import pictures using an image editing program like PS or something. A quick and easy way is to use the Scanner and Camera Wizard that you can launch from Exlporer. If you click on 'Webcam' in the Explorer window, you should see the camera image in the right hand pane. However, you must NOT have this image open while you launch the wizard, otherwise you'll get the following message:
    Creation of the video preview failed. etc...
    Click on any folder _other_ than the Webcam, then right-click Webcam and it should pop up a menu. Select "Get pictures" and that should start up the wizard and you'll see the camera preview.
    Skrunch.
  3. mach_zero
    mach_zero Casual Observer NBR Reviewer
    Just discovered this myself and its actually pretty simple. When you open up the webcam in "My Computer" if you look to the left in the explorer window you will see a link that says "Take a New Picture". When you click on that it snaps a still and you can see it just below the webcam stream, with the default name Picture_001, Picture_002, etc... Just right click on the pic and save it wherever you want.
  4. TTran008
    hmm i dont seem to see that Take New Picture link on the left
  5. MB W163
    MB W163 Notebook Consultant
  6. TTran008
    I think there may be something wrong with my camera utility, because its not there.
  7. TTran008
    ok thanks everyone, i found it, i am an idiot... :)
