PCIe and PCI graphics in same machine
Discussion in 'Gaming (Software and Graphics Cards)' started by tomcom2k, Jan 4, 2010.
  1. tomcom2k
    tomcom2k Notebook Evangelist
    Not notebook related so delete if against policy...
    On a desktop PC if i have a PCIe Dual Head graphics card and a cheap PCI (or second PCIe) graphics card can I run them both and have 3 monitors connected?
  2. moral hazard
    I think it might be fine as long as you arn't using vista.
  3. tomcom2k
    Any reason Vista or 7 wouldn't like it?
  4. moral hazard
    7 would be fine.
    Vista does not allow multiple graphics drivers.
  5. key001
    key001 Notebook Evangelist
    Also as long as you don't mix ATI 'legacy' + ATI non legacy, for example one card is older/worse than x1950 and 2nd is newer than 2400, then you'll have to use 9.3 catalyst. And if you put in a legacy card and 5xxx and get them to work, PM me :)
  6. Greg
    Greg Notebook Nobel Laureate
    I've done this very thing on my old desktop, shouldn't be a problem at all. But you will need to ensure that both cards are either both ATI or both nVidia.
    Now if you have any further questions on this, I would really appreciate it if you could make a thread over at DTR and link to it.
  7. $immond$
    $immond$ Notebook Consultant
    makes sence
