Pavillion DV7-6197 screen replacement to FHD
Discussion in 'HP' started by hpuser09, Dec 3, 2015.
  1. t456
    Good. That's one part down: Chi-Mei N173O6-L02 datasheet and pin-out (page 11). Now you just need to know which panel laptopscreen.com may provide or order an exact model yourself. But, really, this CMO uses a standard interface, so any 1080p 40-pin wled is likely to work.
    Now, not all 1080p's are equal in quality and laptopscreen will just ship whatever they have in stock. If you want a panel that's guaranteed to work and is a splendour to behold to boot, then there's only a single one; B173HW01 V4 (or one the other Vx's, but the V4 is preferable). Sadly, none are available atm (the one listed is an 'RW01'), but this V0 is quite an improvement as well.
    hpuser09 likes this.
  2. hpuser09
    hpuser09 Notebook Enthusiast
  3. hpuser09
    I am going to order the one compatible on laptopscreen. Hope all will be good. I will let you know.. Thanks
  4. hpuser09
    Hi, it's arrived today. It works amazing without any difficulty. It's an AUO. No cable changing or other.. Thank you so much for support man ;)
    Monitor
    Windows description...... Monitor generico Plug and Play
    Manufacturer............. AUO
    Plug and Play ID......... AUO209D
    Data string.............. B173HW02 V0
    Serial number............ n/a
    Manufacture date......... 2011, ISO week 0
    Filter driver............ Monitor
    EDID revision............ 1.4
    Input signal type........ Digital
    Color bit depth.......... 6 bits per primary color
    Color encoding formats... RGB 4:4:4
    Screen size.............. 380 x 210 mm (17,1 in)
    Power management......... Not supported
    Extension blocs.......... None
    DDC/CI................... n/a
    Color characteristics
    Default color space...... Non-sRGB
    Display gamma............ 2,20
    Red chromaticity......... Rx 0,620 - Ry 0,340
    Green chromaticity....... Gx 0,330 - Gy 0,570
    Blue chromaticity........ Bx 0,150 - By 0,060
    White point (default).... Wx 0,313 - Wy 0,329
    Additional descriptors... None
    Timing characteristics
    Range limits............. Not available
    GTF standard............. Not supported
    Preferred timing......... Yes
    Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 140,000 1920 1968 2000 2100 1080 1083 1084 1102 -hsync -vsync
    Detailed timing #1....... 1920x1080p at 40Hz (16:9)
    Modeline............... "1920x1080" 93,330 1920 1968 2000 2100 1080 1083 1084 1102 -hsync -vsync
    Standard timings supported
    Report information
    Date generated........... 17/12/2015
    Software revision........ 2.90.0.1002
    Data source.............. Registry-Active
    Operating system......... 6.1.7601.2.Service Pack 1
    t456 likes this.
  5. hpuser09
    @t456, sorry for question man, you think this is a good screen? Thank you for ...
  6. t456
    Hard to tell, but most likely it's a very big improvement over the old panel. Thing is, the N173O6-L02 was only tested using Gossen Mavo-Monitor and the B173HW02 V0 with X-Rite. That's apples and oranges, so ...
    Main thing is you are happy with the new display and like the result. Is brightness control working, btw?
  7. hpuser09
    Yes man, i am happy, seems works all good, also brightness control.. i think it's a bit pixelated than previous one, i don't know why., but for the rest there are not problem.. ;)
Similar Threads - Pavillion 6197 screen
  1. jweke
    201
