Pavillion DV7-6197 screen replacement to FHD
Discussion in 'HP' started by hpuser09, Dec 3, 2015.
  1. hpuser09
    hpuser09 Notebook Enthusiast
  2. hpuser09
    No one can help me? I must contact hp? I don't know what i can do.. Thanks
  3. t456
    Original cable is fine; both 900p and 1080p use the same interface/cable (dual channel LVDS). If you had a 768p it would've been a different matter, since that requires only a single channel cable (though it would run on the dual as well).
    There are a few other differences, but don't think they apply here, considering you ordered a DV7-compatible. You may assume a 99% success rate, but if you want the other 1% then supply the actual panel nrs. (sticker on the back of the panel).
    hpuser09 likes this.
  4. hpuser09
    t456, thanks so much for your help and reply. So i can ordered the FHD screen w/o change the cable, thanks to confirm me this. It's important for me.
    Only one other thing, always in this page: http://www.laptopscreen.com/Italian/model/HP-Compaq/PAVILION~DV7-6197SL/?set_currency=EUR
    watching the retro screen photos on thi left of the page, you can see any differences about cables between 2 model/resolution screens?
    I see that video connector is always on the left side in all models, and watching this video about similar laptop:
    i see that i need to "use" only 2 connector, the video connector on the left side just like in this video and the power connector above (from minute 10 in the video)
    My thoughts are not for disassemble/assemble etc.., i have already completely disassembled this laptop 2 times in these 5 years to change thermal past and clean all internal dust, this is one of the worst hp laptop about "hot", i have fear that the FHD model needs of one third connector or something, but seems not from those images.
    What you think? Thank you for help, i need of that..
  5. t456
    The panel itself only needs a single cable, the second/top cable is for the webcam and wifi antenna. The display cable combines ~30-40 wires of all three devices in a single cable and splits them off later on. This saves cost on the motherboard connector (only needs one, instead of two or three) and makes for easier routing through the display hinge.
    With CCFL backlight panels you had one or two separate, 2/4-pin power connector(s), but this a WLED type and these require less power, so the regular, tiny LVDS wires suffice to power the backlight. Aside from that, there existed a few high-gamut panels that really had two connectors. None of these caveats apply here, but there's one thing you may want to check; both old and new panel have to be a bottom-left or bottom-right type. This indicates the location of the panel's connector when viewed from the back (the example in the video is bottom-left). Reason is that the length of the cable may not suffice if you have a mismatch, though there are extender cables to work around that possibility.
  6. hpuser09
    Thanks understood, i think i will order the FHD model this week. Seems all compatible, the video connector is on the left side also on FHD model seeing the back of the screen from the images, i have send them also an email about this, probably tomorrow they will reply. I have seen on the same site also the extender cable.. i will let you know, thank you for help
  7. hpuser09
    Hi, i have had 3 replies from laptop screen after explained all like here:
    1)
    Dec 06, 2015 14:33:22
    Ken - chat wrote:
    Thank you for contacting the support team.
    We do not recommend you attempt to upgrade the resolution as more than likely the new screen will not function correctly once installed.
    2)
    Dec 06, 2015 15:04:14
    Ken - chat wrote:
    Im our experience the two resolutions are not directly interchangeable, you will likely also have to upgrade your flex cable connector to one which supports the higher resolution you are installing.
    You are welcome to purchase and attempt the upgrade, however the risk is entirely yours.
    3)
    Dec 07, 2015 8:34:25
    Ken - chat wrote:
    We do not know the flex cable specifics for this exact laptop, we are just relating our experience with other customers who have attempted such upgrades.
    I don't know what to do now :(
  8. t456
    Just provide the panel nr. (use MonInfo) and we'll see which 1080p panels are compatible. If laptopscreen delivers one of those then it'll be fine. I'm wagering 'Ken' assumes you want to upgrade 768p -> 1080p, which is indeed more complicated, but 900p -> 1080p is not an upgrade, since both require the exact same 2-channel lvds interface. Only reason it wouldn't work is that the panels' connector's pin-out might be different (this is unlikely, though). And, again, providing the actual panel nrs. is sufficient to rule out that slim chance as well.
  9. hpuser09
    Thanks so much:
    Monitor
    Windows description...... Monitor generico Plug and Play
    Manufacturer............. Chi Mei
    Plug and Play ID......... CMO1719
    Data string.............. N173O6-L02
    Serial number............ n/a
    Manufacture date......... 2009, ISO week 5
    Filter driver............ Monitor
    EDID revision............ 1.3
    Input signal type........ Digital
    Color bit depth.......... Undefined
    Display type............. RGB color
    Screen size.............. 390 x 220 mm (17,6 in)
    Power management......... Not supported
    Extension blocs.......... None
    DDC/CI................... n/a
    Color characteristics
    Default color space...... Non-sRGB
    Display gamma............ 2,20
    Red chromaticity......... Rx 0,613 - Ry 0,344
    Green chromaticity....... Gx 0,326 - Gy 0,590
    Blue chromaticity........ Bx 0,160 - By 0,082
    White point (default).... Wx 0,313 - Wy 0,329
    Additional descriptors... None
    Timing characteristics
    Range limits............. Not available
    GTF standard............. Not supported
    Preferred timing......... Yes
    Native/preferred timing.. 1600x900p at 60Hz (16:9)
    Modeline............... "1600x900" 107,800 1600 1648 1680 1940 900 903 908 926 -hsync -vsync
    Standard timings supported
    Report information
    Date generated........... 07/12/2015
    Software revision........ 2.90.0.1002
    Data source.............. Registry-Active
    Operating system......... 6.1.7601.2.Service Pack 1
    Raw data
    00,FF,FF,FF,FF,FF,FF,00,0D,AF,19,17,00,00,00,00,05,13,01,03,80,27,16,78,0A,08,05,9D,58,53,97,29,
    15,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1C,2A,40,54,61,84,1A,30,30,20,
    35,00,7E,D7,10,00,00,18,00,00,00,FE,00,4E,31,37,33,4F,36,2D,4C,30,32,0A,20,20,00,00,00,FE,00,43,
    4D,4F,0A,20,20,20,20,20,20,20,20,20,00,00,00,FE,00,4E,31,37,33,4F,36,2D,4C,30,32,0A,20,20,00,AD
  10. hpuser09
    Any news t456?
