Pavilion dv6700 motherboard question...
Discussion in 'HP' started by Izagaia, Aug 9, 2011.
  1. Izagaia
    Izagaia Notebook Evangelist
    I have one of those old dv6700 series (specifically a dv6809wm) notebooks who's motherboard has fallen victim to the warping issue that has affected so many. And yet, I never knew that there was a recall that warranted sending in the unit to HP to correct the issue. As old as it is, I never figured. And I when I did realize there was, it was too late.
    Well - I still want the laptop repaired. I think there are a few good years left in her and to be quite honest, I want to undertake the project just to see if I can do it. But there are a myriad of HP part numbers for replacement boards that I could use. Most of which are interchangeable. Most of the dv6000 boards fit in all of the models available. The default in mine is an AMD-based nForce 560 with the 6150 IGP. No HMDI available. Not exactly what I plan on putting back in it. What I do plan on putting in is HP part no. 459564-001. This MB is also an AMD nForce model but is the "full featured" model with the G86-730-A2 decrete graphics card (nVidia 8600GS).
    What I want to know is if anyone with this MB knows if it is compatible with the Atheros b/g LAN module? The Atheros adapter has a two-wire antenna. I know there are MB's for the dv6700 that use a three-wire antenna for it's LAN adapter. I want to know if this motherboard had two or three plugs?
    Thanks!
  2. neothe0ne
    neothe0ne Notebook Consultant
    By "motherboard warping issue", do you mean the "nVIDIA defect" from 2007?
    Also, GeForce 8600GS sounds like a defective part to me.
  3. Izagaia
    I guess that is what I mean by "warping".
    Anything wrong with the 8600GS or am I misinformed on something?.. it's alright. Wouldn't be the first time. ;)
  4. neothe0ne
    As far as I'm aware, all the entry-level 61xx and 7xxx cards and the 8000 series are a part of the "NVIDIA defect".
