Panasonic Toughbook Won't Power Up or Charge,No LiGHTS!?! HELP!
Discussion in 'Panasonic' started by jtstealthuser, Jan 8, 2010.
  1. jtstealthuser
    jtstealthuser Notebook Guru
    Ugh. Hello this is my first time posting so please, be easy on me as im young and this is my first toughbook and today is the first day i have had it. Anyways, i was tinkering with my CF-28 BIOS(no os installed yet) and it just dies, go to turn it back on and NOTHING!
    So i let sit for a minute tried again and nothing. please help :eek:
  2. ohlip
    ohlip Toughbook Modder
    Its dead, man! j/k but maybe. Are you using a battery alone or is it plug on AC?
    Ok! take it all out the removable component like Ram, Hdd, battery cd rom and then hook it up to AC and turn it on. Let me know.
    ohlip
  3. jtstealthuser
    OMG thanks for the quick awnser, It is currently plugged in and it was when it died. The charge light is not on or anything...
  4. ohlip
    Ok! do you have battery? I mean is there a battery on the unit? If nothing, check your AC adaptor.
    ohlip
  5. jtstealthuser
    And nothing...
  6. jtstealthuser
    er sorry, yes i have a battery but the guy said it may be worn out, removed everything as you said and still nothing, no lights, no beeps no screen flickr nothing
  7. ohlip
    What do you mean "And nothing.., we have still hope I can tell you that. Just explain properly and we gonna troubleshoot what maybe the coz.
    Don't panic! just relax, Btw, Welcome to the forum.
    ohlip
  8. jtstealthuser
    Thanks, Its almost as if its just dead, let me try to explain what happened,
    i connected the hdd and was in BIOS changing the boot order to boot from harddrive. as soon as i clicked "save and exit" it just dies, was plugged into ac. and from there it wont power up. The only thing i can think of is that my AC adapter is AC and the plug on my toughbook is DC. Would that have anything to do with it? Maybe fried something inside?
  9. Doobi
    Doobi ToughBook DeityInTraining
    I have one of those A/C plugs that has a light on the transformer to let me know it is plugged in and getting power. Does yours have a light on it, and is it lighting up? If you plug a light in the same socket as your laptop, does the light turn on normally? Do you have a multi-meter and know how to use it?
    That should hold you for a little while; get back to us on those questions please and we can move forward. If it is mysteriously working now, please let us know that too.
    EDIT: No, it's not an AC/DC thing, that is a band.... :)
  10. moral hazard
    Take out the battery and power cord.
    Then hold the power button for 1 min. Then put the batter and power cord back in and try to boot.
