panasonic toughbook cf-74 will not load up past panasonic boot screen after replacing memory
Discussion in 'Panasonic' started by joe0311, Mar 7, 2016.
  1. toughasnails
    Optical drive : 80gb ?? You do mean Hard disk 80gb ....yes
  2. Shawn
    You have an issue not related to memory.
    Try resetting the BIOS to defaults.
    Remove the DVD drive and try to boot.
    Blair, Here is his photo.
  3. joe0311
    joe0311 Notebook Enthusiast
    Sorry i saw optical drive and it says 80 across from in the picture u just posted, so thats the hard drive ? I know how to use a computer just dont know alot of names and code words for components
  4. joe0311
    Alright i hit f2, go to boot and then select "get default values" then save and exit?
    Or f9 to setup defaults?
  5. joe0311
    Guys i really appreciate this, either one of yall ever get a warramt in texas let me know and ill make it go away
    Shawn and toughasnails like this.
  6. toughasnails
    Yes that is what I do. Also by the looks of it you do not have a cd/dvd drive installed ? Do you have a hdd installed there instead ?
  7. joe0311
    Yes the hdd which is the hard drive correct? Is installed there, i have a usb external player for disc, i loaded all defaults, saved and exited and its still doing the same thing
  8. toughasnails
  9. Shawn
    I have never seen an optical drive show up like that.
    I need to go home for lunch. I will check the BIOS of my CF52 and see what it shows. I have a HDD installed where the DVD normally goes.
    Joe,
    Can you send me a couple photos of the sides of the computer?
  10. Shawn
    If the HDD is in the DVD space then that is the problem.
    A CF74 uses a IDE optical drive. Either they used an IDE drive or an adapter and a SATA drive.
    The adapters are unreliable at best.
    I do have a 100gb IDE drive at home. I do not have a CF74 caddy though.
    Can you pull the HDD and send a photo?
