panasonic toughbook cf-74 will not load up past panasonic boot screen after replacing memory
Discussion in 'Panasonic' started by joe0311, Mar 7, 2016.
  1. joe0311
    joe0311 Notebook Enthusiast
    The issue im having is once i installed the new ram in computer will not load past the panasonic boot up screen, and ive tried switching them around, and even put the old ones back in and it still does the same thing, it didnt do this before at all it worked perfectly, i just needed more memory, currently has a copy of windows 7 on it, i can send anyone photos in email from my phone but it will not let me post them from it, thanks for your help
  2. Shawn
    Make sure the memory is fully seated in the socket.
  3. joe0311
    It is for sure, it slides in tight then u hear it click and it dosent move, send me your email address and ill send u pictures of what it looks like and the screens on the computer itself
  4. joe0311
    I need to figure out something today as fast as possible, not trying to rush you i know your busy with your life but im out of town and i work for the state of texas court system running warrants, need my computer for skip tracing fugitives that are high priority cases
  5. Shawn
    PM SENT
  6. joe0311
    Thanks, i sent u the photos
  7. toughasnails
    If it's booting up that far it almost sounds like a bad hard drive. Press F2 at start up, do you see the memory or hdd in the bios?
  8. joe0311
    Bios:v2.00l10
    System memory:2048mb
    Hard disk: none
    Optical drive:80gb
  9. joe0311
    If i take the hard drive out and try to turn it on phoenix bios screen wont come up
  10. joe0311
    Cpu= 1 processors 2 cores per
    System ram 2048mb passed
    System catch 2048mb passed
    System bios shadowed
    Video bios shadowed
    Fixed disk 0: st980825as
