Panasonic toughbook CF-28 replacing ihard drive
Discussion in 'Panasonic' started by Wyoming88!, Jun 17, 2019.
  1. Wyoming88!
    Wyoming88! Notebook Evangelist
    So you have a Cf-28 but the Hard drive is 20gb and you want 80gb. So I have made this as a guide.
    Step one: Open the back panel with the release sliders.
    Step 2: remove hard drive caddy with pulling up the tab then push and pull on one of each tabs
    Step 3 unscrew the screws with a size 1 (?) Philips-head and pull up the caddy
    Step 4 pull out the hard drive and replace with the other hard drive and do this process in reverse order.
  2. scpres
    scpres Notebook Consultant
    Whats the antenna in cf 28 for? I have a CF30 MK4 with the same antenna ? how can I use it for ?
      File size:
      331.5 KB
      62
  3. Wyoming88!
    I believe that it is for wifi. My personal CF-28 has it
  4. User32
    User32 Notebook Deity
    I was going to say WWAN but I haven't seen a CF-28 in ages.
  5. Wyoming88!
    Maybe. I use Ethernet and rarely use the antenna
  6. toughasnails
    It's been a while since I have been around a 28 but I think the antenna is for CDMA service ??
    katalin_2003 and Shawn like this.
  7. Springfield
    Springfield Notebook Deity
    There were 2 kinds of antennas on later CF-28s: cell (CDMA?) and wifi "B". The cell were common for police car use, but from what I saw the wifi was pretty rare. It was a Cisco card in a PC card slot hidden under the keyboard. I think the wifi was mainly used to connect to a CF-VDW07 wireless display using proprietary software that only runs under WinXP or Win2K. I still have a working setup like this . . .
    toughasnails, Shawn and UNCNDL1 like this.
  8. UNCNDL1
    UNCNDL1 Notebook Deity
    I remember I had to turn off that hidden WiFi to get my added wireless card to work.
    Sent from my CF-M34
  9. Wyoming88!
    What is the wireless card jst wondering
  10. Wyoming88!
    I think that the antenna Is for the wireless card (see attached photo). The 27 also has the antenna so it might be the wireless card
