Panasonic cf-19 touchscreen problem
Discussion in 'Panasonic' started by zahar1968, Nov 15, 2011.
  1. zahar1968
    zahar1968 Notebook Enthusiast
    Suddenly stopped working touch screen.
    pointer does not move, how to check the serviceability of the sensor?
    I opened the screen, check the connection.
    Check the wires that are serviceable!
    Checked the 4-wire touch screen
    between two wires showed resistance Om 340
    How much should it be?
    touch screen is faulty?
    very rarely sensor begins to operate.
    Sorry for the text, write an interpreter
    I live in Russia
  2. Alex
    Alex Super Moderator
    Is this a mk-1 cf-19 ?
    Whats the full model number
    It should be cf-19??????
  3. zahar1968
    sorry, I forgot to MK-1
    CF-19CHBAXBM
  4. RuggedSolutions
    RuggedSolutions Notebook Consultant
    Is more then likely a bad touch-panel. Could be the drivers but I'm sure you checked that already. Has been known to get messed up after a Windoz update. I have yet to have the controler board go bad. Have had 19's with only 50 hours with broken touch-panels and ones with 20,000 hours that keep working. I have new panasonic panels if you need one, PM me. There is a thread here that shows the replacement, it's rather simple.
    Here's the thread: http://forum.notebookreview.com/panasonic/623873-cf-18-touchpanel-lcd-replacement.html
  5. zahar1968
    thanks for the answer
    Laptop bought in February of 2011, his condition was perfect.
    While it is running 3170 hours, I treated him gently.
    No luck .....
    I'll buy your new touch screen
  6. RuggedSolutions
    Ok PM me to order. Thanks.
  7. zahar1968
    Can not write PM, how to do it?
    Posts a little?
  8. SHEEPMAN!
    SHEEPMAN! Freelance
    V,
    Put your email in user cp [edit profile]allow others etc.
    After post a little you can PM. (like you said)
    Welcome to the forum.
    Jeff
  9. toughasnails
    One more post and you should be able to PM
  10. ares93
    ares93 Notebook Evangelist
    I'm pretty sure you need 50 posts before you can pm. Every forum i know has the 50 post cap. That's usually the standard. So new posters wont spam everyone. Its annoying I know, but that's the way it is.
    BTW, is that a Samara in your avatar?
