Pads received with myvlaptop
Discussion in 'Sager and Clevo' started by tayu, Dec 15, 2016.
  1. tayu
    tayu Newbie
    Hi all,
    Got my Eluktronics P650RP6 and in the box I received small pads.
    What are they?
    Sent from my ONEPLUS A3000 using Tapatalk
  2. John@OBSIDIAN-PC
    John@OBSIDIAN-PC Company Representative
    Usually for NVME M.2 SSDs.
  3. Prostar Computer
    Yep, exactly. If you ordered the laptop with an NVMe drive installed by the seller, it might be worth checking out to make certain they applied a thermal pad already.
  4. tayu
    tayu Newbie
    The laptop has a sata m.2 in the NVMe slot, is just for Nvme or every m2 ssd? Is it supposed do dissipate heat?
  5. Prostar Computer
    It's just for PCIe. mSATA drives don't produce as much heat as the PCIe drives.
    Yes, it helps with mitigating heat buildup. :vbsmile:
  6. John@OBSIDIAN-PC
    Sata M.2 drivers do not need it, they do not make much heat.
    NVME PCI-E drives do.
  7. tayu
    tayu Newbie
    Great, thanks.
