pa71hs-g with gtx 1070 and FHD 120hz g-sync problems
Discussion in 'Sager and Clevo' started by nswish, Dec 7, 2017.
  1. nswish
    nswish Newbie
    Hello everyone,
    recently i've bought pa71hs-g with the specification mentioned in thread, however i ve got problems with nvidia g-sync, namely i don t have g-sync options in nvidia control panel. I have already tried reinstalling drivers with clean isntallation and DDU, sadly didn t help.
    Graphic settings in BIOS are set to DISCRETE same in clevo Control Center. Notebook has MSHybrid mode as well.
    Display panel is: Chi Mei N173HHE-G32
    Hope that maybe someone here would be able to help me.
  2. Meaker@Sager
    Did it ever show G-sync? Did it come with an OS installed?
    nswish likes this.
  3. nswish
    nswish Newbie
    It came without OS and no, there was no g-sync option from the begining, firstly i thought that mb drivers update would help but no.
  4. Legion343
    Legion343 Notebook Consultant
    The Chi Mei N173HHE-G32 is FHD and it isn't certified for G-Sync in Clevo. Only FHD IPS / 120 Hz QHD from AUO / QFHD 4 K are certified for Clevo.
    I guess that maybe Prema could have added this panel to BIOS if he would wished.
    nswish likes this.
  5. nswish
    nswish Newbie
    Oh well, than i think i need to contact with my reseller, because their offer contains information which says it supports g-sync
  6. Meaker@Sager
    I think that's your best option. Maybe there was a mix up.
  7. Cim
    Cim Newbie
    Hello, @nswish
    I have the same issue like you, i dont have G-sync activated on display panel: Chi Mei N173HHE-G32, what you did !? you replaced your machine, or you found something to activate G-sync ?!
    If someone can help me, i will be so glad.
    I want to contact Prema, but i think he dont have time to make a bios for Clevo PA71HS. offfff....
    Happy new year, to all!
  8. nswish
    nswish Newbie
    Sadly my reseller confirmed that there is no g-sync for this model and there was misinformation in their offer.
  9. Meaker@Sager
    Yes just external displays for that.
  10. Chastity
    Well, the unit is GSync capable, just that the internal panel isn't.
