pa70hs-g pa71hs-g and hp6-g are locked to 1468mhz
Discussion in 'Sager and Clevo' started by tanzmeister, Jan 5, 2018.
  1. tanzmeister
    tanzmeister Notebook Evangelist
    hi! I am experiencing severe throttling and lock on 1468mhz on all pa70 models incl pa70hp6-g and pa71hp6-g
    the issue arises when GPU hits 72-76C or so(always random) and the GPU frequencies gets caped at 1468Mhz and never goes beyond that until reboot!
    @Prema @Meaker@Sager @XMG, can you make any input on this issue?
    it also occurs more often and faster with newer Nvidia drivers, the supplied DVD drivers seems to do it really rarely.
  2. MahmoudDewy
    MahmoudDewy Gaming Laptops Master Race!
    I had that problem in the past with an early GTX880m and sometimes it would get stuck at low clocks till you do a driver reinstall or a vBios re-flashing ... The funny thing is that this was fixed in a certain Nvidia driver update and never happened ever since. Try changing drivers across drivers families and see if the problem persists.
  3. tanzmeister
    I think I have found the reason for this problem, though it's a manufacturer's fault, there seems to be a workaround! I will keep this updated soon.
    MahmoudDewy likes this.
  4. BrinNutz
    BrinNutz Notebook Guru
    What have you figured out?
    I changed my Nvidia 3D Power Settings from Optimal Power to Maximum Performance, and that fixed it regardless of temps. But, then it randomly reverted back to 1468mhz again. Restarted and it was back to 1873mhz.
  5. tanzmeister
    I have found that building an MSI afterburner curve, to make the card consume 119watt help with clocks
    the lock to 1458 Is not random, I have figured there are 2 triggers for this: temperature higher than 72C and 121watt power draw at the same time!
  6. Tuan Hoang
    Tuan Hoang Notebook Consultant
  7. tanzmeister
  8. Matthew Gary
    Matthew Gary Notebook Consultant
    Would you mind sharing the afterburner curve profile?
  9. tanzmeister
    I can, but it's really individual.
    best thing you can do is to open HWINFO64 and monitor your cards TDP, build the curve so it never exceeds 120watt for gtx 1070, maybe 119 even better!
  10. thegh0sts
    thegh0sts Notebook Nobel Laureate
    and you can't check because the tool doesn't work with it?
