P950 - How do you disconnect the EDP display cable from the motherboard site
Discussion in 'Sager and Clevo' started by djsubtronic, Mar 12, 2019.
  1. woodzstack
    woodzstack Alezka Computers , Official Clevo reseller.
    Yeah these thinner laptops can be a pain in the buttocks sometimes with these sort of things.
  2. KevC123
    KevC123 Newbie
    I am having trouble opening the back. It is mandatory to pop the keyboard out in order to open the back?
  3. djsubtronic
    djsubtronic Notebook Evangelist
    Yeah, the 5 screws under the keyboard also secure the bottom cover so you will need to remove them.
  4. KevC123
    KevC123 Newbie
    Opened the back and noticed this broken thin cable at the hinge that doesn't look like the replacement cable sold on aliexpress
    There are two of them that go through each hinge, and one is broken. Does anyone know what cable is that? Screenshot_20190327-011706.jpg
  5. Meaker@Sager
    Display and wifi cables go through there usually.
  6. djsubtronic
    Yea one of mine is broken too, it's for the WiFi. Signal dropped a bit at longer ranges but otherwise not an issue.
  7. Meaker@Sager
    It will push it to run single channel, I'd speak to your reseller.
  8. Prostar Computer
    It's possible it was prevalent at one point, maybe a bad batch, as Meaker said. Thanks! I'll be on the lookout.
    I agree about talking with your seller, it might be worth it to let them handle replacing it. Things could get worse with normal wear and tear, and re-routing a replacement cable is a bit of a pain.
  9. djsubtronic
    If the cable is cut short at the hinge, how does it affect the operation of the WiFi card as there is still a antenna cable connected to it, just a bit shorter...?
  10. Meaker@Sager
    That's a bit like saying a ladder is fine if it's missing the top rungs. The antennae is at the top of the screen and sized to pick up the right frequencies.
    djsubtronic likes this.
