p870tm 2nd CPU fan port!
Discussion in 'Sager and Clevo' started by tanzmeister, Jan 9, 2018.
  1. Encryptonite
    Encryptonite Notebook Enthusiast
    Papusan likes this.
  2. jc_denton
    jc_denton V̖̟en̰g̻̼̰̩͙ea̲n̪c̭e̼ ͍̘̤͓̟̤Is̙͔ ̤Mi̻̭̣͎͍ͅn̰ḙ
    So the 4th header on the p870tm1 has actual power running trough it, and will power a 5v fan. However, the fan has to be correctly rewired, as the 4-pin header on the mobo does not use the standart pinout as pointed out earlier in the thread.
    If you plug a standart 4-pin fan to it without rewiring you might blow you mobo as some people have in the past.
    Here's a good thread to read up on it.
    @aarpcard used a Delta BSB05505HP-SM 5v fan. I went with a slightly thinner Sepa HY60Q05AP 5v.
    Delta fan is ~8-10mm thick depending on where you measure it, while the Sepa fan is 5mm.
    You want to leave pins 2 & 3 unterminated, only using pin 1 and 4 to power the fan (+5v and ground).
    This will make the fan run 100% always.
  3. Meaker@Sager
    I would advise not getting a whiny fan.
  4. jc_denton
    You wont notice that with fn+1 anyway. :p
    Papusan likes this.
  5. Encryptonite
  6. Meaker@Sager
    Different frequency of noise, you will probably notice it quite a bit as a discordant tone.
  7. jc_denton
    Papusan likes this.
  8. Meaker@Sager
    Extra height would also he wasted ad the fon stack is only so high.
  9. TheReciever
    TheReciever D! For Dragon!
    Hmm, going to try something similar on my Ranger I think. I have a 12v fan already, would just need to make sure its appropriately wired for a desktop pinout.
    I can then use my other heatsink idea for my GPU.
  10. Meaker@Sager
    I'd discuss over at the alienware section regarding where to power it from.
