p870tm 2nd CPU fan port!
Discussion in 'Sager and Clevo' started by tanzmeister, Jan 9, 2018.
  1. Jon Webb
    Jon Webb Notebook Evangelist
    The fan on the right. Did it fit and did it work? What are the part numbers? Thanks
  2. ole!!!
    ole!!! Notebook Prophet
    it doesnt fit as nicely as the one on the left in terms of the fan part itself but the 4pin head fit nicely, left fan has pin issue the pin hole being too small and together. both these fan need wiring re-route so neither is plug n play. right now i still have the left one in the machine because im waiting for 12v fan, and additional wire/JST pin heads to do splitter.
    right fan is this on ebay https://www.ebay.com/itm/282590636507
  3. ole!!!
    sicily428 likes this.
  4. Meaker@Sager
    If it draws too many amps you risk trying your motherboard.
  5. Danishblunt
    Danishblunt Guest
    unless you try to kill your mainboard you shouldnt ever buy that thing
  6. Meaker@Sager
    Or have a power circuit drawing from something more substantial.
  7. ole!!!
    i could get an additional source, for example from all other fan slot. also 1.1A is what it claims rated at, use it in a desktop and find out just how much it needs at full RPM. probably stronger than the clevo fan for sure.
  8. Rayleyne
    Rayleyne Notebook Consultant
    I know i'm going through an old thread @ole!!! did you ever find out if a fan worked properly in that slot, Plug and play so to speak?
    Encryptonite likes this.
  9. Encryptonite
    Encryptonite Notebook Enthusiast
    I'd like to know, as well
  10. Papusan
