p870tm 2nd CPU fan port!
Discussion in 'Sager and Clevo' started by tanzmeister, Jan 9, 2018.
  1. bennyg
    bennyg Notebook Virtuoso
    So it spins? Constantly or up and down with the main CPU fan?
    DIY mods step 1... reach for the cable ties.
  2. JCordero31
    JCordero31 Notebook Consultant
    Like a turbine all the time i removed it
    AHMED KARAM, Prema and bennyg like this.
  3. Meaker@Sager
    Maybe as a compromise use a variable resistor to find the right value and mod it to something reasonable.
  4. ole!!!
    ole!!! Notebook Prophet
    donno if EC controls it or what not i'd treat that fan as disposable and have it run at all time. feels pretty weak tbh, could be because no lid so less air pressure. gonna make a lid for it which will also help mount to circled screw holes. double circle = screw grip can put a thin screw and mount it. single circle its used by the bottom cover so already has a screw, just need something that has a circle and held in place by it.
    ps. after putting on bottom cover theres actually quite a bit more space, i dare say a 8mm fan would fit. will purchase 8mm fan and try next.
    AHMED KARAM and sicily428 like this.
  5. Papusan
    I'm ready for my next BGA-KILLER with 4 fans:D Maybe we will see GeForce GTX 2080 before the summer. But I want the full package.... 4 fans, 8 core i7 and 2080 Sli →→→ My BGA-Killer from 2015 will finally get a brother:)
  6. Meaker@Sager
    A lid is needed for a blower fan certainly. In that config most of it is just spun in 360 degrees out.
    ole!!! likes this.
  7. poprostujakub
    poprostujakub Notebook Consultant
    Do you connected fourth (probably blue) wire to connector? This is speed control for this fan.
    sicily428 likes this.
  8. ole!!!
    im more interested in single 2080 and z390 for possible PCH onboard wifi/bluetooth. if ipex connector is even built in along with PCH then i can use the wifi A+E slot for something else.
    single 2080, 8 core, 4 fans, and lots of storage mods.
  9. bennyg
    What about splicing in PWM from primary CPU fan connector?
    FWIU, PWM is a pretty standard electrical signal that wouldn't be affected by splitting the wire into two?
  10. ole!!!
    i could try that, just have to figure out which color is the right one, blue/yellow for this HP fan. also even if i figured out the correct one how would i be able to test it to verify if i got the right one or not, FN+1?
    currently with just GRND and 5v, in gaming its around 3-4 degree cooler, but the constant noise
