p870tm 2nd CPU fan port!
Discussion in 'Sager and Clevo' started by tanzmeister, Jan 9, 2018.
  1. radolf
    radolf Notebook Guru
    I now also have the fan.
    I have looked at the cables. Apparently, assignment is already correct. You can theoretically connect the fan without regard to the rest of the connections.
    Probably PWM and SENS signal is also the same as in the wiring diagram of the P870TM!
  2. jc_denton
    jc_denton BGA? What a shame.
    Papusan likes this.
  3. radolf
    Thank you, I already knew that! I meant only the cables from the fan itself. But it does not really matter, I also operate the fan only with 5V plus and ground! Works fine:).....
    jc_denton likes this.
  4. jc_denton
    Ah great :) I just made it a habit of mentioning it every time it comes up, since a 400$ replacement mobo is not so nice.
  5. Jaces9900
    Jaces9900 Notebook Geek
    so curious on the power needed for a i9 9900k stock , with a gtx 1080 on the p870tm1-g?? will a 330w work fine or should i do a dual or a 780w , and any pointers for the intel raid set up each time i try i get a kernal error , no matter how i load windows or any os , if i got non raid ahci all good .... but my gtx 1080 is running avg temps of 87-90c
    rzrwolf and jc_denton like this.
  6. jc_denton
    Yes, a single 330W brick should be fine. I still use a single 330w at 5.1Ghz and powermodded 1080 without issues.
    rzrwolf likes this.
  7. Meaker@Sager
    I'd avoid any power viruses though.
  8. rzrwolf
    rzrwolf Notebook Geek
    So 9900k +rtx 2080 should also be fine?
    BTW, how do you guys attach the second fan? Just capton tape/scotch?
    Sent from my S60 using Tapatalk
  9. jc_denton
    It should be alright, the 2080 has a lower TDP than the 1080 afaik. I did some testing with a wattmeter and the 330w brick scales well above and has held up fine so long. As for the 2nd fan, you can either make mounting for it, there are 3 screw holes or just duct tape it in place. I'd also put a small thermalpad between where it sits to reduce vibration noise.
    rzrwolf likes this.
  10. jc_denton
    Perhaps, I've only tested my personal usage, which is benching and gaming, so that's something to keep in mind.
