p870tm 2nd CPU fan port!
Discussion in 'Sager and Clevo' started by tanzmeister, Jan 9, 2018.
  1. jc_denton
    jc_denton BGA? What a shame.
    I really doubt that there is enough space for that internally and having the back cover on as well. Unless, you add spacers and can live with gaps around the system.
    Not to mention depending on where you position the fan, EMI might do a number on some components.
    luisxd likes this.
  2. Meaker@Sager
    Lol, not very difficult on these guys to be fair.
  3. jc_denton
    Which is a good thing, only the CPU heatsink can be a dread, if you want to get gunk out from the rad. Since that requires removing the tape that holds fan and the heatsink together.
  4. luisxd
    luisxd Notebook Consultant
    I just found out that it doesn't fit lol
  5. jc_denton
    You can fit a ~60mm fan on the TM1 heatsink, as long as it's 5-8mm in height. Anything above that requires modding the back cover depending in where you place the fan.
    Spartan@HIDevolution and luisxd like this.
  6. luisxd
    Yeah, bot the connector and the fan doesn't fit. I'll try to scavenge a fan from an old laptop.
  7. jc_denton
    It's a 4pin 5v, but it needs to be rewired, since the board uses a non standart pinout.
  8. jc_denton
    You might even fit a larger fan, but it requires cutting off some of the metal mounting brackets on the heatsink, which might not be for all.
    ole!!! likes this.
  9. CrazyD
    CrazyD Newbie
    Possible to use the port for cooling the GPU? And can some send me an example which fan will fit on the GPU heatsink? thx :)
  10. Meaker@Sager
    What's your current heatsink? The best upgrade is the vapor chamber and that usually does not need help if setup properly.
