P870KM1 1080 SLI issue (possible dead card?)
Discussion in 'Sager and Clevo' started by ascottuk2010, Sep 24, 2019.
  1. ascottuk2010
    ascottuk2010 Notebook Geek
    Hi All,
    So i bought a P870KM1 from @DaMafiaGamer which has been superb and what a great guy as a side note. Came with a single 1080 and i always had the intention of going SLI hence i bought the additional PSU and splitter again from @DaMafiaGamer
    I bought an additional 1080 from @Dr. AMK again a top top guy arrived reasonably swiftly considering the holidays
    Before installing i modded the heatsink as per instructions with a pure copper 0.5mm shim and was all good to go, i used 6wmk thermal pads as per instructions also
    Installed and everything was perfect, temps where good, the only issue i had was the slave card from @Dr. AMK seemed to be drawing up to 205w, this subsequently settled down over the next week and both cards where drawing around 180W
    Temps where fantastic, the primary card topped out at 73 degrees and the slave around 78 degrees
    On the weekend the machine failed to post at all,it turned on for a few seconds then off, nothing on the screen just black.
    Below is the troubleshooting i have done
    Removed the slave and the machine posts fine
    Swapped the cards around so the slave is in the master and master in the slave, machine fails to post same behavior as above
    removed both cards, same behavior as above
    put just the slave card in the master slot, same behavior as above
    So essentially i think the slave card is dead, i have no other machine to test it in either unfortunately as my brothers machine died a month ago.
    I am back running with the single 1080 that came with the machine absolutely fine, both the card are exactly the same revision
    Does anyone have any other ideas on what i can do to test or eliminate anything else as i am stumped and left with a rather heavy paperweight after less than a month of use
  2. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    Seems like the slave card has killed itself. Were the thermal pads making good contact on the vrm sides?
  3. Dr. AMK
    Dr. AMK Living with Hope
    I'm sorry for what happened, I assure you that the card was in 100% working condition.
    Is the vBIOS for both is the same?
    The copper 0.5mm shim, if it pushed hard the GPU core it will damage it, for all normal vapor chamber heatsink there is no need for any shims.
    I suggest that you attache some pictures for the card from both sides.
  4. ascottuk2010
    Absolutely, nice slight indents from the pressure. As for the copper shim, its exactly the same as the one @DaMafiaGamer has on the other side, if anything it was not making enough contact till i repasted with a slightly thicker TIM (Kryonaut)
    I will post some photos tonight, i had a really good look through a small magnifying glass and it doesnt shoy any circuit breaks, but i mean in all honesty its not that powerful to look through so i could have missed something
    Vasudev, DaMafiaGamer and Dr. AMK like this.
  5. Dr. AMK
    For the card and the VP heatsink as well.
  6. ascottuk2010
    IMG_0004.JPG [​IMG][​IMG]
    Hi guys,
    Had more of a play and still the same
    Attached the above
  7. Meaker@Sager
    There is no defined slave card so they can be swapped for testing or either one run I individually.
  8. ascottuk2010
    Already done this as above
    Removed, and tested the new card on its own and doesn’t post
    DaMafiaGamer likes this.
  9. DaMafiaGamer
    Whats the mark near the vram chip??
  10. ascottuk2010
    Just some left over thermal pad from the old pads that must have been applied, the phobya ones I have a dark grey
    I’m utterly stumped now
