P870DM-G 1060 Upgrade Issues
Discussion in 'Sager and Clevo' started by Nmanfred, Dec 20, 2018.
  1. Nmanfred
    Nmanfred Notebook Consultant
    Hello Everyone,
    I am in need of some assistance. I just got my P870DM-G and had a 1060 that I plan on using until I get the funds for a single 1080, or SLI 1070. I was able to install the 1060 pretty easily, it boots and loads into windows without issue. When I modify the .INF and install the drivers, they install successfully, but the screen goes black, and I cannot get the display back unless I boot to safe mode, and uninstall the drivers. This is on a fresh installation of Windows 10. I tried both 417.35 and 417.22, both had the same issue.
    I can hook it up to an external display via HDMI and it works fine, I was able to run a Firestrike run successfully.
    I am not sure where to start, does this sound like a driver issue? Should I try more drivers? Could this be a vBIOS issue? Just looking for some guidance.
    Thanks everyone
  2. poprostujakub
    poprostujakub Notebook Consultant
    Known issue. You need compatible vBIOS for your card.
  3. Meaker@Sager
    It does sound like a vbios HDCP type issue.
  4. qwerty8224
    qwerty8224 Notebook Guru
    gtx1060 clevo ? MSI?
  5. Nmanfred
    It is an MSI 1060
  6. Nmanfred
    Does anyone have any other vBios that I can try out? I have tried G Sync and non G Sync vBios from an MSI laptop. I have been searching and haven’t found many other vBios’s to try. I have also tried several older drivers, I went as far back as 375 drivers, and same thing.
  7. Meaker@Sager
    Have you checked the techpowerup database?
  8. Nmanfred
    I have, I tried all of the vBios I could locate on there. I ended up “figuring” it out. I had a feeling it may be something to do with the display, so I removed the 1440P AUO display that was installed, and reinstalled the 1080p screen. For whatever reason, I am able to install the drivers and the internal display works correctly.
    Danishblunt likes this.
  9. Danishblunt
    Danishblunt Guest
    I was about to say because the 1060 has insanely high compatibility across the board.
    The whole monitor thing is really odd tho.
