P870DM Display Question
Discussion in 'Sager and Clevo' started by TheDantee, Feb 13, 2018.
  1. TheDantee
    TheDantee Notebook Evangelist
    I have a P870DM-G and I was considering swapping the 1080p display for a 4K Display after I upgrade to 1070 SLI (or maybe a 2000 Series Card when released...) Does the panel have to be specific is my question for example I can't find a 1440p 120Hz option but if I put a 17" panel in there plugged it into would it display an image same with a 4K screen if I bought a screen that was not the stock AUO B173ZAN0 would it still display an image?
    Sent from my unknown using Tapatalk
  2. bennyg
    bennyg Notebook Virtuoso
    Aliexpress, eBay, taobao, etc
    4K is B173ZAN01.x
    1440p 120Hz is B173QTN01.x
    You will need upgraded EDP cable as well
    If you get B173ZAN01.0 or B173QTN01.0 you will retain Gsync
  3. TheDantee
    But any 17.3 should technically work right I could care less about gsync since my 980Ms can't use it anyway
  4. bennyg
    Both panels I mentioned are factory options for P870, that is as close as you can get to guaranteed compatibility. Otherwise, the potential issues abound; GPU, system and panel firmware all have to be able to communicate successfully. The panel also has to have the connector on its rear side in the same spot or the cable might not reach. The dimensions or screwholes may even be different requiring modding to fit.
    The panels still represent the upper limits of high DPI and high refresh @ 1440p respectively; they can both still be found for us$100-150 covered by aliexpress/ebay return policies. I don't get why you would want to choose something else?
  5. Meaker@Sager
    With panels you have to worry about size, mounting and electrical connection type/position.
