p775tm1-g gtx1080 heatsink fits for rtx 2070
Discussion in 'Sager and Clevo' started by VaaS77, Apr 23, 2021.
  1. VaaS77
    VaaS77 Newbie
    Hi need for advice.
    Want to upgrade my gtx 1080 to rtx 2070.
    p775tm1-g heatsink fits for it or a need to look for it.
    And may be some one hade that upgrade.
    BIOS upgrade.
  2. Meaker@Sager
    There is a heatsink that will fit perfectly or you will need to mod yours a bit IIRC. You will want to be on the latest BIOS from your reseller.
  3. VaaS77
    VaaS77 Newbie
    Ok thanks.
  4. Meaker@Sager
    No problem and good luck :)
