P775TM1 Build Help
Discussion in 'Sager and Clevo' started by _H_, Feb 13, 2020.
  1. _H_
    _H_ Notebook Enthusiast
    Hello Everyone!
    I've got my first barebones laptop coming in next week. I'm pretty competent with computer building/repair, i'm an E.E. by trade which means absolutely nothing because 90% of my co-workers can't even change out an electrical socket. I'm somewhere between "able to reflow a GPU with an smd station" and "definitely not a smooth-brain" I'm really just looking for some pointers on how to get the most I can out of my laptop. The parts I have currently are: RTX 2070, i9-9900k(which i'm planning on delidding as soon as my LM comes in), and a WD 1tb SN750 NVME. This computer will not be used solely for gaming as I do 3D modeling, Coding, Visual design, as well as a decent amount of 2D CAD. I have several questions listed below, if you're willing to share your knowledge and experiences with me I would be very grateful!
    Questions:
    1) BIOS: I'm assuming a good BIOS is a great start to maximizing what I can do. Can I get a good BIOS flashed through USB or do i need to break out my skypro II again? What is/Who has the best BIOS for customization?
    2) RAM: I've seen some P775TM1's listed with DDR4-3200 and some with a max of DDR4-3000, is this a bios thing?
    3) RAM: Does 3200 make a worthwhile difference over 3000? If so are there any particular options you'd recommend? Vengeance, HyperX, Ripjaws?
    4) WLAN: Whats the word on WiFi 6? Any m.2 form-factor cards that support it and are supported by the laptop?
    5) WLAN: Are the Killer cards that much better than Intel? Explain your answer with a 3 paragraph essay :vbbiggrin:
    6) Thermal: What will keep my temps way down, I have no problem with fan noise. Are there upgraded fans I can get? Do better thermal pads matter on the heatsink? Lets get this thing cool so I can overclock it!!!
    7) POWWA: I'm guessing a 330 watt charger isn't gonna cut it for extreme gameplay. Does the 2-1 660watt(2x330) adapter actually matter? Is the 780watt adapter worth the money?
    8) MISC: What am i missing? Are you sitting there thinking "how could this moron forget about "xxxxx", what a stupidface-dummyhead" I'm willing to learn and welcome all suggestions, Let Me Know!!
    Thank you for reading :vbtongue:
    Edit 1: I've gone with Crucial Ballistix DDR4-3200 CL16 BL2K16G32C16S4B as my ram. Reasoning below :). Also I chose a RTX 2070 as i'm planning on doing a TDP mod to get ~2080 performance.
    Edit 2: I've gone with an Intel AX200 over a killer card, less bloatware same card. Power doesn't seem to be an issue. Things are still in progress for thermals!
  2. Meaker@Sager
    3200 and 3000 are not that different typically.
    Physical stuff would be first, ensuring perfect contact and adjusting thermal pads to achieve that.
    _H_ likes this.
  3. _H_
    Thanks for the advice!
    I'm usually extremely careful with my installations to a fault as I've wasted my fair share of TIM and time just rechecking my work.
  4. _H_
    Update: I've decided on my RAM. I'm going to go with Crucial Ballistix DDR4-3200 CL16 BL2K16G32C16S4B. The price was right compared to the other DDR4-3000 options and the timings for other 3200 that I saw sucked. I can include a link if anyone is interested
  5. Meaker@Sager
    The model number works, the best source is going to vary by region after all.
    _H_ likes this.
  6. Clevobest
    Clevobest Notebook Enthusiast
    Why you want to put more than 2666 ram???I9 9900k support max 2666,so more than this is waste of money.
  7. Papusan
    Ever heard about Intel XMP? And you know that Clevo LGA laptops support it?
    jc_denton likes this.
  8. Clevobest
    Yes i know that,you can put xmp 300000000x,i9 or i7 8700k support ONLY 2666 mhz transfer data between ram, chip and cpu,if you got ram on 3000mhz,the cpu gonne take only 2666.Intel 8 and 9 generation support max 2666,with intel 10 generation is another storry support DDR4-3200, LPDDR4-3733: https://ark.intel.com/content/www/d...1065g7-processor-8m-cache-up-to-3-90-ghz.html
  9. Papusan
    And here I sit with an 5 years old Clevo P870 running 9900K on old Z170 chipset and oc'd ram. Stock ram speed 2133MHz running 2802 or better say ram oc'd +31%.
    _H_, jc_denton, Spartan and 1 other person like this.
  10. Meaker@Sager
    They can clock up to 3200mhz quite easily on the desktop, it's a little trickier on the crowded tracing on the notebook but doable. You get some reasonable performance scaling up to about there from 2666mhz.
