P775DM3-G thermal pads?
Discussion in 'Sager and Clevo' started by joluke, Jun 22, 2019.
  1. joluke
    joluke Notebook Deity
    What are the best thermal pads for my laptop? And which ones to buy? I've seen several heights. 1mm, 1.5mm, 2mm and 3mm. Which ones should I buy? My laptop is 2 years old and I never replaced them. So to avoid future problems I'd like to purchase new ones. Thanks in advance
    Sizes are in millimeters btw
  2. Vasudev
    If you have high ambient temps and changing temps both inside and outside your house choose Arctic(0.5mm,1mm and 1.5mm) or Gelid pads(available in most sizes(mm)). Otherwise if you're a Pro choose Fujipoly pads which are brittle and needs replacing if you repaste often. Gelid and arctic survive even after multiple teardowns.
    Arrrrbol and joluke like this.
  3. Meaker@Sager
    The softer pads will give more consistent good contact.
    Arrrrbol, Vasudev and joluke like this.
  4. Arrrrbol
    Arrrrbol Notebook Evangelist
    They are a bit expensive but I've had good luck with the Gelid pads. They are soft enough to deform a bit and are not too brittle so they will last a while. They will start to harden after a long time though, but it won't be an issue if you keep your heatsink in place for long periods.
    Papusan, Vasudev and joluke like this.
  5. joluke
    Thank you everyone for your comments!
    So, 0.5mm, 1mm and 1.5mm are enough right? I'm going for ARCTIC ones.
    Vasudev and Arrrrbol like this.
  6. Meaker@Sager
    A sheet of each of those should have you covered.
