[P775DM3-G] Please Help lastest vBIOS GTX 1080 10DE-1BE0
Discussion in 'Sager and Clevo' started by DuongTHVN, Mar 11, 2020.
  1. DuongTHVN
    DuongTHVN Notebook Guru
    Hi guy!
    I have a Sager NP9172 (P775DM3-G) with GTX 1080 my vBIOS version is 80.04.56.00.2A with gpu clock 1657Hz - boost 1847MHz
    i have research a newer vBIOS is 86.04.2A.00.2B with boost is gpu clock 1557Hz - boost 1771Hz
    https://www.techpowerup.com/vgabios/186530/clevo-gtx1080mobile-8192-160706
    is that official vbios and how can i use that's?
    if is it not official please share to me the official bios
    thanks
  2. Meaker@Sager
    If you are not having issues don't change it. It will perform slower.
    DuongTHVN likes this.
  3. clevo-extreme
    clevo-extreme Company Representative
  4. DuongTHVN
    thanks!
    i know it but i have issuse is when i full load both CPU and GPU, my GTX 1080 is overheated. My screen display that (image) then BSOD.
  5. clevo-extreme
    Check bios. Reflash. Display cable. Another GPU test.
    Fastest Customizable Gaming Notebooks & Mobile Workstations | CLEVO Integrator
  6. Meaker@Sager
    Do your fans spin normally? If so a bios wont help, cleaning and a repasting will be your best options.
  7. Niaphim
    Niaphim Notebook Consultant
    To not create duplicates, I will up this topic.
    I'm looking for a GTX 1080 vBIOS (P775DM3-G) as well.
    I've flashed the vBIOS mentioned in the first post and it turns out it doesn't support UEFI (the impact of which I didn't fully understand) and lost G-Sync capability (if this makes sense) .
    So now I'm looking for the latest (or any working) UEFI-compatible vBIOS
  8. Khenglish
    Khenglish Notebook Deity
    Your card is damaged. No driver or bios change is going to fix it.
  9. DuongTHVN
    so sorry.
    when i flash lastest vBIOS it fix my error and GPU work perfect.
    goodluck for your damaged card.
  10. Meaker@Sager
    What was the version ID?
