P770zm Hibernation issue
Discussion in 'Sager and Clevo' started by LogantheHamster, Oct 10, 2019.
  1. LogantheHamster
    LogantheHamster Notebook Enthusiast
    Hi,
    I have the odd problem that whenever I put my laptop to sleep (power saving) or similar, by for example closing the lid, it wont recover as it should when I start it again.
    To be more precise it turns off into hibernation as it should after the set amount of time, though when I turn it on afterwards the first boot attempt always fails and the system shuts down or freezes, forcing me to start it again or hard reset it. Note here that it usually just shows me thos Premamod Bios logo, never getting to the loading circle effect. Also not that extremly rarely instead of doing nothing or beeing freezed it automatically restarts. Either way I always end up with a freshly (cold) started Windows system and not one that woke up!
    I have yet not found out the reason/s for this extremly annoying bug, but hopefully you can help?
    Kind regards
    Logan
  2. Meaker@Sager
    Are you running any non stock settings? Are you on the latest firmware?
  3. LogantheHamster
    Hey, every hardware is on stock settings, nothing OCed, every driver is up to date, Windows as well though it is still on1809. Also Control Center is not installed, so there should be no issues related to this * software. Instead I am using the tools made by obsidian atm. And besides enabling UEFI I didn't do much else in the bios.
  4. Meaker@Sager
    Try 1903 and the latest firmware.
  5. LogantheHamster
    Hi, sorry for the late reply got a nasty cold.
    Anyways I did as you suggested but this only caused more issues.
    Now I have a variant of bluescreens, sometimes even when cold starting the device, some driver have issues (TouchPad for example), the sleep when the lid is closed sometimes won't work and odly I can't enter the safety mode of windows anymore. It always tells me that my password is wrong. I even changed it and tried again and reloged my account.
    Also Windows 10 forbids me to go back to 1809, the option is just not there.
  6. Meaker@Sager
    Sounds like it has got corrupted. Are you running stock?
  7. LogantheHamster
    Sorry what do you mean with "Are you running stock?"?
  8. Meaker@Sager
    Stock clocks and voltages for cpu/memory etc.
  9. LogantheHamster
    Ah that, yes everything is still on stock (was too distracted yesterday to get it ^^). Though when the laptop is running i tried out the other default profiles of the Obsidian Control Center and with those active the pc is running smoothly aswell.
    I think it either has to do with a driver or with Windows 10 1903 itself. Or maybe some of the hardware is no longer fully supported?
  10. LogantheHamster
    Oh and when the PC is running it does so smoothly, unless i set it to sleep, hibernation or whatever. Just the normal restart usually works. And the BSOD errors I get vary from BAD_POOL_HEADER, RQL_NOT_LESS_OR_EQUAL, PAGE_FAULT_IN_NONPAGE_AREA to SYSTEM_SERVICE_EXCEPTION. So totally general and not really helping stuff, but when it helps I can upload the eventlogs.
Similar Threads - P770zm Hibernation issue
  1. wrc gator
    188
