P75XDM2/P75XXTM cooling!
Discussion in 'Sager and Clevo' started by anassa, Jul 19, 2020.
  1. joluke
    joluke Notebook Deity
    The cooler of the laptop is the one on sale on aliexpress!? This is amazing to be honest
  2. ViktorV
    ViktorV Notebook Enthusiast
    [​IMG] [​IMG]Aliexpress is very overpriced, I take directly from the supplier, so it turns out a little cheaper
    Cylix101 and joluke like this.
  3. Cylix101
    Cylix101 Notebook Consultant
    Wow, nice setup and temps, i am impressed. Thinking more and more to get one of these..
  4. ViktorV
    This radiator is for a liquid cooling system, without it it is able to keep the temperature around 82 degrees under load.
    Cylix101 likes this.
  5. Cylix101
    You mean the heatsink without the water pump? What Cpu is inside? 9900k and 2080 as gpu`?
  6. ViktorV
    Yes, the radiator without being connected to a water cooling system will maintain the temperature within 82 degrees under load. The tested laptop has an i7-9700k processor and an RTX 2070 video card, a laptop with an i9-9900kf processor and an RTX2080 video card with a connected water cooling system shows the same temperature results.
  7. yrekabakery
    yrekabakery Notebook Virtuoso
    82C on the GPU isn’t that impressive imo. Turing thermal throttles at 87C so it’s pretty close to the temp limit. Not to mention, the TGP is only 115W on the 2070 and 150W on the 2080, and the dies are huge so thermal density is lower. I get lower than that on air cooling with a much more thermally dense 190W 1080.
    jc_denton and joluke like this.
  8. ViktorV
    58 degrees on GPU, do you have less?
  9. yrekabakery
    Ah didn’t see that, video was blurry. If I limit my GPU to 115W and max out fan speed, my temp is in the low 60s.
  10. ViktorV
    [QUOTE = "yrekabakery, post: 11077936, member: 695118"] If I limit my GPU to 115W and max out fan speed, my temp is in the low 60s. [/ QUOTE]
    With hardly believe it, but what will happen to the performance of your GPU and how to deal with the noise from the fans
