P751DM2-G: installed second M.2 drive, now usb is failing when using HTC vive.
Discussion in 'Sager and Clevo' started by sebastiank, Mar 30, 2018.
  1. Stooj
    Stooj Notebook Deity
    That is totally strange. My first thought would be power related but they use different voltage feeds and I'd expect everything to fail simultaneously.
    Only other things I can think of would be checking for new drivers, new BIOS update (there's several for the P751), re-installing the OS and maybe contact Prema in regards to his BIOS mod (he may also know more about the issue itself).
    If you could achieve the same load under Linux you may also get far better error logging as the windows events tend to be garbage for debugging.
    Failing that, I suspect you're only left with RMA.
  2. XMG
    XMG Company Representative
    The VIVE isn't really hammering the USB connection in terms of data/bandwidth load, but it is continuous usage. Something like an external hard drive would utilise the USB much more - have you tried something like this as well, with the same problems? It's pretty mysterious, I haven't seen a report like this before.
  3. Meaker@Sager
    It could be the southbridge itself has an issue, very rare but could happen.
  4. sebastiank
    sebastiank Notebook Enthusiast
    Prostar Computer likes this.
  5. Meaker@Sager
    Thanks for that, must be a low level I/O conflict on the standard drivers. Good to know +rep.
