P751DM2-G: installed second M.2 drive, now usb is failing when using HTC vive.
Discussion in 'Sager and Clevo' started by sebastiank, Mar 30, 2018.
  1. sebastiank
    sebastiank Notebook Enthusiast
    Solved: check post #14
    I'm experiencing an issue with my clevo and a high bandwidth usb devices (HTC vive and kinect) after installing a Samsung 960 M.2 EVO 250GB next to the already installed 512GB Samsung SM961 M.2. When using the device for a couple of minutes the usb seems to drop out, tries to reset or fails completely until the system is rebooted.
    On some occasions I get this report in device manager: Windows has stopped this device because it has reported problems. (Code 43). A USB port reset request failed. When this happens all USB ports become unusable until I reboot.
    On other occasions the vive disconnects without the error in device manager. When that happens I can software reset the vive, but the same problem occurs again after some time.
    A few times the system also shuts down (without a BSOD). In the realiability monitor I get this report:
    When I remove the 250gb M.2 drive from the system the problem doesn't occur and everything works fine.
    The HTC vive is connected to the USB 2 port and HDMI. The problem also occurs on any other usb port.
    So I wonder where to look and what to try in resolving this issue.
    This is what I tried so far without result:
    Formatted the 250gb m.2 drive
    Swapped drives
    Only the 512gb drive in other slot
    Maybe the m.2 drive itself or the laptop has hardware issues, or some kind of conflict?
    Or the 960 draws to much power?
  2. Meaker@Sager
    It's all running through the chipset, if an odd conflict is going on it could cause issues. Have you tried taking an image backup of the 250GB drive, formatting it and then inserting it as blank?
  3. sebastiank
    I just reformatted the drive as NTFS and did a test, the problem still occurs.
  4. Meaker@Sager
    Does it change anything if you swap the slot the 512GB is using?
  5. sebastiank
    Thanks for your suggestions so far!
    I just swapped them, and tested, but the problem still occurred.
  6. Meaker@Sager
    Now if you keep the 512GB in the same slot you moved it to does the problem still persist without the other drive?
  7. Stooj
    Stooj Notebook Deity
    That...is really strange. The USB and SATA/M.2 lanes only ever converge for the 3G/LTE M.2 slot and the WiFi M.2 slot.
    You can try running a Linux ISO, plugging everything in and seeing if it all detects (use the "dmesg" command to see things like USB reset errors).
    The only things I can think of from a hardware standpoint is if the PCH is faulty or power delivery is faulty (although it'd be unlikely for 1 M2 slot to work and the other to fail as they're both supplied by the same 3.3V line).
    Have you tried swapping the M.2 SSDs around? Then you should be able to see if the same slot fails both time.
    Alternatively, you may want try using a USB 3.1 Type-C -> USB 3.0 hub. The USB 3.1 Type-C ports are supplied by the Alpine Ridge chipset which run completely separate to the regular PCH USB controller.
  8. sebastiank
    Just tested, with only the 512gb in the other slot it works fine.
    Papusan and Falkentyne like this.
  9. sebastiank
    The devices show up fine in different operating systems, the problem starts to occur only when using the vive. I've tested with other high bandwith usb devices (kinect 2, webcams) but then it doesn't occur.
    Yeah in different configurations, also with the 250gb formatted to ntfs. The problem doesn't occur when the 250gb drive is removed from the system, and the 512gb drive is in the first or second slot.
  10. sebastiank
    A small update to this, the problem doesn't only occur with the HTC vive. I just had a longer session 3D scanning with a kinect, and the same problem occurred after some time. When removing the second 250gb drive it didn't occur. It seems that any high bandwidth device triggers the usb to shut down and .reset
