P750DM2-G From HID
Discussion in 'Sager and Clevo' started by PeenX2, Apr 8, 2017.
  1. PeenX2
    PeenX2 Notebook Enthusiast
    Does it on stock speeds too though...
  2. Phoenix
    Phoenix Colonel
    you can't use the battery on such high performance clocks man, think of a battery as a backup not as a means of using the laptop. This is not your typical portable laptop. You can try to stay on the balanced plan and see if the clocks hold higher
    TomJGX likes this.
  3. PeenX2
    Well that's a bummer. It has nothing to do with CPU clocks though, they stick where they are no matter what. Even with bios default's it has the same issue. Something to do with GPU I'm sure, like the BIOS won't allow the GPU to do much on battery.
    Can barely browse the web on battery, even 100% stock bios settings. Was hoping to be able to unplug once in awhile and use the internet. The battery lasts almost 3hrs on full charge, but pointless since it's unusable.
  4. Phoenix
    Phoenix Colonel
    ill have a look soon, gimme a moment
  5. Meaker@Sager
    It should still browse ok, which browser are you using?
  6. PeenX2
    Chrome, Edge, FireFox, IE...they all lag horribly. It games fine on battery.
    Everything is set High Performance, tried setting card to Max Performance in nVidia Control Panel. Checked DPC latency, all good. Tried a seperate OS install as well on another SSD, still lags. Tried BIOS reset too.
    Feels like some sort of hardware limit to me. Once I plug back in, it's fine.
  7. Meaker@Sager
    Try it with a more balanced profile and at stock instead.
  8. PeenX2
    I've tried both, all profiles and 100% stock bios settings.
  9. Mr. Fox
    Have you already tried disabling hardware acceleration in your browser? This being enabled causes me all sorts of stupid issues and it also prevents the GPU clocks from dropping into 2D mode when enabled.
    If not, maybe give that a try. IE, Edge, Firefox and Chrome all have options for this. In Chrome go to the Advanced Settings and clear both check boxes under "Settings" then restart the browser.
    Prostar Computer and Phoenix like this.
  10. PeenX2
    Yeah, I always turn it off anyways because of the same reasons you described.
