P670RE overheating
Discussion in 'Sager and Clevo' started by srx, Aug 24, 2016.
  1. srx
    srx Newbie
    So, I got a laptop from notebookguru recently (germany) and now it started overheating.
    Its an I7-6700 with 24GB of ram and a 970m nvidia. I play some lighter games like WOW and LOL and do statistics and data sim in R (hence the RAM needed).
    It has the best cooling paste available and all the vents are clear. Today it shut down so i decided to ask around.
    I was playing a game (League of Legends) and listening to youtube in the background and the screen just went black. I repeated the process using CPU-temp and saw that it gets SUPER high if I game and watch youtube at the same time. It seems that they both just hog the core1
    Now this is a top end laptop, this shouldnt be happening. I had no issue doing this on an i3 6GB lenovo with an nvidia 530m.
    Anyone this happened to before? What could be the cause? All help appreciated.
  2. Support.2@XOTIC PC
    What temps does it hit?
    deadsmiley and hgfischer like this.
  3. srx
    srx Newbie
    100+ celsius according to CPU temp. The CPU temp icon gets red and soon after it shuts down.
  4. dragon2016
    dragon2016 Notebook Enthusiast
    wow it's too much , you should maybe repast
  5. srx
    srx Newbie
    after 4 months of use already? thats kinda crap. I can try.
  6. deadsmiley
    deadsmiley Notebook Deity
    There is something definitely wrong. No way should the CPU get that hot under normal usage. Is the fan working? You can monitor/test this with HWInfo64.
    Sent from my overpriced Galaxy S6 Edge +
  7. Zoltan@zTecpc
    Zoltan@zTecpc Company Representative
    You should start with the repast even if it worked fine until now
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    deadsmiley likes this.
  8. Support.2@XOTIC PC
    Yes way too high IMO. I would repaste as well.
  9. srx
    srx Newbie
    Ill try HWinfo and post results
  10. sirana
    sirana Notebook Deity
    At times, the factory applied thermal paste sucks, many people here recommend repasting yourself with IC Diamond (good for beginners, easy to apply and effective) as soon as you get the notebook shipped.
