P650RS/PB51DF2 Power Adapter compatablity
Discussion in 'Sager and Clevo' started by robamb2002, Jul 31, 2020 at 2:57 PM.
  1. robamb2002
    robamb2002 Notebook Consultant
    Hi All,
    Well, my Clevo P650RS-G has seen better days and I'm looking to upgrade sometime in the next few months.
    I've got my eye on the Clevo PB51DF2-S. I mainly will use it at two locations, home and work. I purchased a spare power supply with the P650 and loved not having to cart the brick around with me. So, here is my question; Can I use my current 230W (100-240V~3.2A input 19.5V=11.8A output) Power supplies as a backup kept at work, or do I need to buy a second power supply to keep at work?
    They both look the same, have the same input/output and what looks like the same connection. but I'd like to confirm before I pull the trigger.
    Also, are there any negatives to using an older power supply? They are both in really good condition since neither had to travel daily.
    Thanks!
  2. Meaker@Sager
    All barrel types for clevo are 5.5mmx2.5mm so if both are rated the same you should be good to go.
  3. robamb2002
    good deal! Thanks!
  4. Meaker@Sager
    Just make sure you get a branded adaptor, don't go no name. FSP and delta are a couple of examples.
