P650HS-G PC Freezes while Turboboost is enabled and undervolted
Discussion in 'Sager and Clevo' started by jinwk00, Jul 19, 2019.
  1. jinwk00
    jinwk00 Notebook Enthusiast
    My P650HS-G freezes whenever I undervolt more than 0.100, and even so my temperature is extremely high, around 80c. I had to disable turboboost to make my computer stable, but still my temperature doesn't seem to be normal. Currently in undervolt 0.120 and turboboost disabled. I see a lot of people do 0.140 and turboboost on, still have a cool temperature. Is there something wrong with this machine?
    Example I found that I would never be able to achieve
  2. Meaker@Sager
    What version of XTU are you using?
    You should never have to disable turbo so something is up. A repaste would be a first step and checking out the heatsink.
  3. jinwk00
    I recently repasted my pc, and I tried using the latest XTU. I also tried throttlestop and turned off turbo, barely saved my a$$, 60c
  4. Meaker@Sager
    80c load is not dangerous by the way.
  5. jinwk00
    Although 75c was the normal idle? With turbo
  6. Meaker@Sager
    It should not be at turbo boost during idle.
  7. jinwk00
    But help me! My laptop is always staying up like this! Even on idle!
  8. Meaker@Sager
    Set it to balanced performance in the power plan and see what processes are using the CPU.
  9. jinwk00
    Looks like I fixed it by reducing the power to Better Performance.
  10. Meaker@Sager
    Temperatures and freezing?
