p640hk1 7700hq draining battery ASPM disabled!
Discussion in 'Sager and Clevo' started by tanzmeister, Mar 26, 2017.
  1. tanzmeister
    tanzmeister Notebook Evangelist
    tried that
  2. Mr. Fox
    What Windows version? I assume Windoze OS X, but is it RS1 or RS2? Have you confirmed the power profile CPU minimum power state is 5% on battery? Perhaps Windows Maintenance is running too frequently? You can disable that and see if it helps.
    If you are using Clevo Control Center perhaps that is screwing things up. Certainly would not be a first time for that, LOL?
    Have you tried uninstalling Clevo Control Center?
  3. Meaker@Sager
    A fresh OS install is worth a try if you can with a monitoring app to see if something causes the change as you install drivers.
  4. TomJGX
    TomJGX I HATE BGA!
    Yup, I agree... I think the OS installation is screwed!
    Sent from my LG-H850 using Tapatalk
  5. tanzmeister
    oh, what have I tried... useless! everything I could ever think of! fresh install, latest win X from iso, updates, services disabling, drivers installing/uninstalling. no luck :(
    tried that too many times
    tried many times, different builds. same ISOs work perfectly in this sense on other Clevo 7700hq laptops.
  6. Prostar Computer
    @tanzmeister - Did you ever contact your reseller? It might be worth it to have them inspect the battery and the board - maybe even replace the board, if nothing else (if they're willing, after inspection).
  7. tanzmeister
    Ionising_Radiation and Prema like this.
  8. Ionising_Radiation
    Ionising_Radiation ?v = ve*ln(m0/m1)
    Clearly an RMA solves everything. Though it would've been interesting to see exactly what was the issue—possibly a faulty resistor on the motherboard, or somesuch...
  9. XMG
    XMG Company Representative
    Good to hear it's been resolved.
    Indeed - @tanzmeister - what did the RMA report say regarding the repair/resolution?
  10. tanzmeister
    I did not ask actually, to be more correct I have RMA'd the board, not the whole barebone.
    but now I am wondering that all what might have been needed is a EC power drain reset?
