P375SM and GTX1070
Discussion in 'Sager and Clevo' started by andrewff2, Oct 25, 2017.
  1. Danishblunt
    Danishblunt Guest
    Ok first of all, you NEED to fix your CPU. Don't let the CPU run on adaptive voltage, it's a disaster, I have a 4940MX and it's just being way to hot and drains way to much from the system without any reason. My CPU runs now @ 4ghz stable and 70s c on load, before it ran unstable 3.4-3.5ghz while being 90c, seeing that you have a haswell as well you should probably fix that as well.
    As to why the card runs so bad, did you try and turn MSI afterburner on and see if it gives you any voltage or power lim errors?
    bennyg likes this.
  2. Meaker@Sager
    70C under what tests?
  3. andrewff2
    andrewff2 Notebook Evangelist
    Running 3DMark, Crysis 3 bench, tombraider...
  4. andrewff2
    Ty for the help the problem is i have no idea how to do this kinda thing i'm bad with this stuff, for example i cannot change from static to adaptative..
    66bruno66 likes this.
  5. Danishblunt
    Danishblunt Guest
    XTU and aida stresstest 30min.
    @andrewtff2 It's really not that hard, just read up on a couple of things and then you can do it as well.
  6. 66bruno66
    66bruno66 Newbie
    Hi Andrew i saw that you are brazilian im too and also have a p375m i have some doubts , can you pls send me you email adress ?
  7. Meaker@Sager
    A small adaptive undervolt will help your idle temps as well as load temps.
  8. andrewff2
    hey man send me a PM so we can talk and sorry for the next year answer :D
  9. nixliu
    nixliu Notebook Consultant
    did not pass 75ºC? are u using fn+1?
  10. Striker1234
    Striker1234 Notebook Consultant
    Is there any way to have 2 1070 in SLI?
