P35W v2 News
Discussion in 'Gigabyte and Aorus' started by shempmalone, May 14, 2014.
  1. chris_laptopfan
    chris_laptopfan Notebook Consultant
    Sorry for asking again, but what do you mean by '... overall it's pretty great with cooling unless you max out everything it will get super hot...'?
    Do you mean, that the temps are higher if you max the games out? Crysis 3 wasn't maxed out? Would only the notebook surfaces get hotter or the gpu/cpu temps as well?
  2. Thrall2004
    Thrall2004 Notebook Enthusiast
    Hi guys,
    I'm also thinking of buying the P35W V2. But untill now there are no complete reviews (with real Benchmarks of different games etc.). Could you please add some? since now the Laptop is not avaiable in Germany. Thanks in advance.
    Best Regards
    Thrall
  3. WhiteBoySHady
    WhiteBoySHady Notebook Consultant
    Oh I mean for this kind of power cooling is pretty great and CPU never goes over 91deg and gpu max is 85 deg so it's pretty great. I just mean the top alluminum surface gets hot only so you don't wanna touch that. Cause the heat sink is right under it .
    If you use the cooling pad, it gpu temp drop by 10 deg to 75
    CPU will still be 91 lol
  4. µGamera
    µGamera Notebook Geek
    Heat can, however destroy the internals of a laptop over extended use...The motherboard/batteries/power on both my HP G62s fried that way .
  5. Frugoo
    Frugoo Notebook Enthusiast
    I will do a complete write up of some testing when I get the laptop tomorrow.
  6. µGamera
    Appreciated Frugoo,
    When you do would you perhaps be able to run at least an hours worth of gaming at high-ultra on it, I just need to see what the extended use on this computer would be like, I usually have my computer on for long periods of time, sometimes maybe I'll want to game for 3 hour sessions or so, I want to know that I will be able to run games for 3 hours without a particular hitch, or how I can.
  7. Frugoo
    What game do you have in mind for that test? I see people posting Crysis 3.
  8. WhiteBoySHady
    Ok here you go pumpkin, I'll give you you're 3 hour test lol
    See you in three hours haha
  9. Thrall2004
    Thank You so much for your effort.
  10. WhiteBoySHady
    After almost 3 hours playing but that's with a cooling pad
    Even same temps with crysis and Alan wake [​IMG]
