P34W v3 First look, impressions and tests - a Pretty Little Beast
Discussion in 'Gigabyte and Aorus' started by fanchiuho, Feb 1, 2015.
  1. Amal77
    Amal77 Notebook Deity
    Works fine on mine.
    Using Samsung 840 Evo 1TB mSATA.
    AU Optronics B140HAN01.1
    No, it doesn't downclocked.
    As if it's plugged in.
  2. fanchiuho
    fanchiuho Notebook Enthusiast
    I guess I wasn't the patient type...
    TheNightWolf likes this.
  3. sisqo_uk
    sisqo_uk Notebook Deity
    thanks i just bought one with no laptop for it LOL
  4. R3d
    R3d Notebook Virtuoso
    Does the new BIOS change the fan profile? I just got mine and this thing is pretty loud.
  5. fanchiuho
    TBH it depends on how many hours of use there is in your typical school day.
    I have long consecutive lectures from 11 to 5 and the 63 Wh can barely make it at the lowest brightness, stealth fan, no backlight, no windows effects etc. Turning on wifi only when you need it helps with that a long way.
    Pixelproof likes this.
  6. mandeep
    mandeep Notebook Consultant
    Do you hear the fans when idle and when performing low intensive tasks?
  7. Pixelproof
    Pixelproof Notebook Enthusiast
    That's probably around how many hours ut will be, I really don't know how many hours yet, because there are some month until I start there. That is a bit disappointing, though, so I have to think a bit bore about the laptop then.
    Anyway, thanks for the answer!
  8. R3d
    It tends to bounce between low and off when doing things like browsing the web. Low is pretty audiable.
    Also, has anybody been able to stop the CPU from throttling without turning off turbo boost? I still get throttling while playing BF Hardline, even after a 65mV undervolt and ICD repaste.
  9. fanchiuho
    So after the pic yesterday I thought I'd share my experience repasting the CPU and GPU :)
    Stuff you need:
    Screwdriver (I used mine for glasses)
    Better-than-stock paste (i.e. anything you can buy for more than $5), using my trusty NT-H1
    Isopropyl alcohol (75% or 99% are both ok)
    Facial tissue
    Patience;)
    RAM slots opened, very naturally a first step for me
    Unscrewed everything. Took extra care to not let screws fall too far. I'd say group those screws too for easier re-screwing.
    Note that there are two screws with stickers on it, most likely a warranty seal. Continue this step at your own risk.
    A nice, copper surface. I guess every bit of cooling helps.
    Naked with two round shapes (NSFW)
    Seriously though, preserve those chrome fan stickers. That way you won't bust your warranty.
    NIC and SSD model in case you are curious.
    Interesting placement. Guess they went into great lengths into the real estate.
    I digress. Now loosen the three screws on each die out slowly and all is left is the sticky compound.
    Can't say it's a bad pasting really, but I usually won't expect much either.
    Look at the gunk above the CPU die!:eek:
    3 swabs and a couple tissue later...
    Honestly not a bad temp, GPU receives a five degrees cut and the CPU a whopping 8 degrees:cool: I <3 Noctua 4ever:D
    I'll need some time before I can adequately log more temps into Afterburner so stay tuned.
  10. daza100
    daza100 Notebook Geek
    Nice job good temps i just did my Aorus x3 and i am not that happy with my results. I will try Noctua paste and that's a weird location for the msata slot. lol
