P205-S6267 satellite... XP? Heres where im at...
Discussion in 'Toshiba' started by prightup2, Apr 29, 2007.
  1. lepoidvin
    lepoidvin Newbie
    :err: oooops it's the PCI device driver annnnnd the Ethernet Controller
  2. dki378
    dki378 Newbie
    Shubes,
    I just recently purchased a p205-s6237 laptop and thanks to all the input on this thread, I was able to successfully install XP without a hitch.
    I was wondering if you were able to figure out the whole F6 and F7 brightness control thing? I would really like to have that functionality back.
    On another note, does anyone know how to change the resolution of the touchpad after loading XP?
  3. ..ziGG
    ..ziGG Newbie
    ok folks i found out what the problem was for the touchpad not working on my p205 running on XP:: i tweaked the BIOS setup back to DEFAULT just by pressing the F9 key and saving the changes made and after that i done a reinstall of the driver provided in the disk 1 of the toshiba recovery cd, plus i installed the on/off touchpad utility you can download from the toshiba website and voila, everything works now.
    i can only assume that the IRQs were probably moved during my first XP install (?) cause i never touched the machine's setup before and the touchpad worked fine under vista
    i decided to post this in case anybody has encontered the same annoying problem.
    good luck to everyone!!!!!!!!
    i guess that's all from me for now.. .. .. ;)
    nice one -ziGG
  4. mostacho
    mostacho Newbie
    hi, i just turn it to XP, everything is working ok... thanks for all this info,
    but the webcam does not work with the original program.
    same as OldTechGuy, can anyone help me?
  5. Shubes
    Shubes Newbie
    Unfortunately, no. I never could get the function keys to work correctly. I found a small, inexpensive program called Magic Hotkey that works wonderfully, if not better. I can control not only the brightness with my function keys, but the contrast AND the gamma settings as well.
    Yeah, it's annoying to have to install an external app to make the function keys work, but I sure like having XP.
  6. mostacho
    mostacho Newbie
    well, its done... to make the webcam original soft run correctly
    i put the program in compatibility with win95
    right clik over the icon, propeties, compatibility and there you are.
    thanks to everyone.
    -*Argentina*-
  7. prightup2
    prightup2 Newbie
    see my new post same title.."P205-S6267 satellite... XP?"
  8. MsTina73
    MsTina73 Newbie
    What is the original software for the webcam on the P205-S6267? I just recieved the computer and it had already been converted to XP Pro everthing seem to be working but there is no program for the Webcam or the Lableflash.
    I would like to be able to use the webcam but i have no idea where to start.
    thanks, Tina
  9. ergec
    ergec Newbie
    prightup2 you are #1. All drivers are worked for my notebook toshiba satellite u305-s5087 . Wireless, network card, modem, sound, graphics all of them. thank all you guys.
    Tohsiba site sucks, drivers on toshiba site also suck, none of them works.
    you are the best guys :)
  10. Jankes
    Jankes Newbie
    Hi i have the same problem. I can't find lan drivers for the toshiba p205. A link witch was in this subject dont include drivers for lan. Could anyone upload the corect drivers?? Drivers on the web dont work correct maybe i can't choose corect ;/ Please help :)))))!!! A one milion of props from me !
