P205-S6267 satellite... XP? Heres where im at...
Discussion in 'Toshiba' started by prightup2, Apr 29, 2007.
  1. OldTechGuy
    OldTechGuy Newbie
    Hey defjam90, I have been going through the same struggle as the rest of you guys, trying to find working drivers to revert the P205 S6267 to a decent OS(XP). So far, by reading in this forum and taking the advice of others on drivers, I have been able to get rid of all the faults in Device Mangler.
    I found that when I installed the Intel chipset drivers (intel 8.3.1013 all.exe), that the installation package included drivers for the Intel wireless as well.:)
    The only problem I have now is that the sidebar for the webcam crashes as soon as I click on anything. Anyone having this same problem, or have a suggestion as to how to fix it? Thanks in advance.
  2. stkim89
    stkim89 Newbie
    prightup2, looks like you are the one who started all this XP madness and did a great job of gathering the resources. (I was almost ready to shoot myself when my screen kept going blank after installing the wrong version!) Hopefully you can help me out. I have tried installing the ethernet drivers multiple times with no success. It keeps telling me that the driver was corrupted or something like that. Did anyone else have that problem while migrating back to XP? Any advice would be appreciated.
  3. Mule
    Mule Newbie
    You guys need to make your life easier
    go to this site:
    http://www.driverpacks.net/DriverPacks/
    1. download all the driver packs to a folder called packs
    2. extract all the packs (7zip) to another folder called drivers
    3: copy your xp source disk to another folder called xp source
    4. Download nlite 1.4 and install
    5. follow directions for loading drivers and making bootable iso
    6. nlite will use all the drivers downloaded and your xp source to make a bootable xp install disk already loaded with all the drivers you need - yes it will be a DVD install disk but it will work.
    I had all the drivers except the modem and flash driver (see my previous post)
    The modem and synaptics drivers are on the delivered install disks.
    If you really want to be on top of this you can slipstream your XP install disk to be patch current when you install too..
    see http://www.ryanvm.net/msfn/updatepack.html
    I would copy my xp sp2 install disk to my hard drive and update it with RyanVM
    Then I would use nlite to make a new iso with all the drivers
    I don't use MS update for patches - they screw up computers and use resources - I use autopatcher:
    http://www.neowin.net/forum/index.php?showtopic=564234
    That was a quick 10 years experience in one post.....
    Don't forget read about this stuff - so you can teach others.......
    Mule
  4. ..ziGG
    ..ziGG Newbie
    hi folks.. i still cannot get the touchpad on my p205 s6237
    so if anyone's interested in giving a hand...:
    i did install the driver (synaptics touchpad driver B25765C.EXE) from the toshiba P205-S6237 recovery disc, it appears identified as: Synaptics touchpad v6.3 on the mouse properties window and as Synaptics PS/2
    Port touchpad
    on the Device Manager window but the touchpad itself just DOES NOT FUNCTION. it did work with Vista though. I also installed toupad-xp-1782-en, which is an touchpad on-off utility but that didnt help either.
    can I ask you::
    1_ how is your touchpad identified on both device manager and touchpad properties windows on your satellite p205 please?
    2_ which driver did you install?
    any help greatly appreciated!!!!!!!!
    nice one!!
    ..ziGG
  5. Mule
    Mule Newbie
    I would recommend uninstalling the synaptics driver completely and using the one from the recovery disk -- I'm running XP and it works great
    Mule
  6. ali69
    ali69 Newbie
    hi
    I have Toshiba satellite p205-s6237 ,XP SP2
    Iinstalled:
    1.infinst_autol.exe -OK
    2.win2k_xp142550.exe -OK
    3.Problem with iata70_enu.exe .I see screen "this computer does not meet the minimum requirements for installing this software" ??
    what can i do ??? I need this program???
    4.atheros_v5_1_1_9.exe -OK
    5.WDM_R166.zip -OK
    6.B25766B.EXE (Modem) -OK
    7.qe15flashdriver.exe -OK
    8.rtlsetup-pcie(664).zip -OK
    I not have yellow cautions,komputer working OK,but not have: iata70_enu.exe.Can I live without this program???
  7. Mule
    Mule Newbie
    You did a good job.
    If you have no yellow caution flags under device manager - you are okay.
    Mule
  8. ali69
    ali69 Newbie
    Thanks ,it's goooood news for me !!!!!!!!!
  9. lepoidvin
    lepoidvin Newbie
    same here i just bought a toshiba Satellite A200-AHI
    PSAE0C-AHIO6C got all the drivers except the device driver that i badly need because i live in the sticks and have only dial-up can anyplease help me i downloaded the pack from the first gentleman on this thread they worked fine EXCEPT the device driver please help
  10. Padmé
    Padmé NBR Super Pink Princess
    What device driver??????????
