P205-S6267 satellite... XP? Heres where im at...
Discussion in 'Toshiba' started by prightup2, Apr 29, 2007.
  1. prightup2
    prightup2 Newbie
    anyone doe this yet...it only comes with vista but my programs wont run on
    vista.
    I did the reformat install with a XPpro-sp2-corp CD
    (make sure you delte both partitions to one large unformatted partition then..
    partition and Format as you wish...)
    Found enough stuff to boot up and work..but...
    had to go to intel to get the
    mobile chipset 945GM drivers
    (covered graphics card and SM bus drivers)
    drivers that will not load;;; :(
    *Ethernet controller-PCI\VEN_10EC&DEV_8136
    *Mass Storage Controller-PCI\VEN_104C&DEV_803B
    *PCI Device-PCI\VEN_8086&DEV_27D8
    details I found listed below but struggling to find the right drivers...
    appears to be...<Name>Realtek 8111 LAN Driver</Name>
    <Test>('PCI\VEN_10EC$DEV_8168'|'PCI\VEN_10EC$DEV_8136')$('Win98'|'WinME'|'Win2K'|'WinXP')</Test>
    - <Action TODO="Web">
    <DrvVer>5.658.0814.2006</DrvVer>
    <Test>('Win98')$('PCI\VEN_10EC$DEV_8168'|'PCI\VEN_10EC$DEV_8136')</Test>
    <Path>SDriver\Network\PCIE\Win98\SDriver.rrf</Path>
    Name: Texas Instruments PCIxx12 Integrated FlashMedia Controller
    Device ID: PCI\VEN_104C&DEV_803B&SUBSYS_FF311179&REV_00\4&6B16D5B&0&22F0
    Driver: n/a
    <Name>Realtek HD Audio Driver</Name>
    <Test>((('PCI\VEN_1002$DEV_437B'|'PCI\VEN_1002$DEV_4383'|'PCI\VEN_10B9$DEV_5461')$('Win2K'|'WinXP'))|(('PCI\VEN_8086$DEV_2668'|'PCI\VEN_8086$DEV_27D8'|'PCI\VEN_1106$DEV_3288'|'SUBSYS_11501462'|'SUBSYS_13701462'|'PCI\VEN_8086$DEV_284B'|'PCI\VEN_1039$DEV_7502'|'PCI\VEN_1462$DEV_7251')$#('MBID_MS-7028'|'MBID_MS-7033'|'MBID_MS-7046'|'MBID_MS-7052'|'MBID_MS-7053'|'MBID_MS-7058'|'MBID_MS-7091'|'MBID_MS-7187'|'MBID_MS-7255')$#('Win32s'|'NT40'))|(('PCI\VEN_10DE$DEV_0269'|'PCI\VEN_10DE$DEV_0371'|'PCI\VEN_1002$DEV_437B'|'PCI\VEN_1002$DEV_4383'|'PCI\VEN_10B9$DEV_5461'|'MBID_MS-7203'|'MBID_MS-7207'|'MBID_MS-7207PV'|'MBID_MS-7225'|'MBID_MS-7250'|'MBID_MS-7252'|'MBID_MS-7260'|'MBID_MS-7270'|'MBID_MS-7303'|'MBID_MS-7309')$('Win2K'|'WinXP')$#('MBID_MS-7298')))</Test>
    <DrvVer>5.10.0.5324</DrvVer>
    <Test>('Win2K'|'WinXP')$#('MBID_MS-7115')</Test>
    <Path>SDriver\Sound\Realtek\HD\SDriver.rrf</Path>
    <Size>32.8MB</Size>
    </Action>
    <DrvVer>5.10.00.5172</DrvVer>
    <Test>('Win2K'|'WinXP'|'Win2003')$('MBID_MS-7115')</Test>
    <Path>SDriver\Sound\Realtek\HD_7115\SDriver.rrf</Path>
    Any ideas would be greatly appreciated...
    Cheersmate.
  2. prightup2
    prightup2 Newbie
    I GOT ONE OF EM...
    Texas Instruments PCIxx21 FlashMedia Driver for Windows XP
    file name...qe15flashdriver.exe - extract and manual inst driver
    (it extracts in a flashmedia.temp\windows dir from the zip)
    In my efforts to spell it out in search of help...i found it...at toshibas web site...not listed as being for the p205 but loads without the yellow ?.
    Cheersmate...now for the realtek HD and ethernet crap...
  3. prightup2
    prightup2 Newbie
    K something found something lost...Got the realtek HD drivers for this...
    filename...WDM_R166.zip
    but it exposed...
    -modem device on HD audio bus
    ven id hdaudio\func_02&ven_11c1
    <Name>Agere Modem</Name>
    <Test>('HDAUDIO\FUNC_02$VEN_11C1$DEV_3026$SUBSYS_11C13026'|'HDAUDIO\FUNC_02$VEN_11C1$DEV_3055')$('WinXP')</Test>
    <DrvVer>2.1.60.0</DrvVer>
    <Path>SDriver\X1024\Modem\SDriver.rrf</Path>
    <Size>1MB</Size>
    agere got bought by lsi and i cant find any drivers...damn..
    anyone..?
    cheersmate...
  4. prightup2
    prightup2 Newbie
    SUCCESS...
    Well i did it...the laptop works....no yellow exclamations...sweet...
    Problems and file name below....
    *Ethernet controller-PCI\VEN_10EC&DEV_8136 rtlsetup-pcie(664).zip
    *Mass Storage Controller-PCI\VEN_104C&DEV_803B qe15flashdriver.exe
    *PCI Device-PCI\VEN_8086&DEV_27D8 is WDM_R166.zip
    Then...u get
    -modem device on High Definition audio bus
    ven id hdaudio\func_02&ven_11c1 TOSHIBA Software Modem.zip
    damn...all because toshiba doesnt want to support XP on these new models...
    and the toshiba web and support sucks...even the profile search only searches the first line of text
    Cheersmate...ill check back and see if anyone needs me...
    I zipped all the files needed and put them up on FLYUPLOAD...
    hXXp://www.flyupload.com/?fid=2163293 (replace the hXXp with http)
    enjoy
  5. jpfiset
    jpfiset Newbie
    Thanks for this post. Although not a laptop, those instructions are valid for my HP Compaq Presario SR5010NX
    The Presario comes equiped with Vista, but the machine is not powerful enough to run it. Therefore, the experience is too slow.
    Using the files you posted, I was able to install XP and install the right drivers for the Ethernet controller, the audio chips and the video card.
  6. prightup2
    prightup2 Newbie
    Sweet gald it helped someone...its tough for an xp lover today...
    specially on new hardware...thank god there is the open source community.
  7. AdamSas
    AdamSas Newbie
    Hello!
    I have also a problem with Toshiba A200 Series - I bought it with Vista and reinstalled to XP. Most of the drivers I found on the internet, but there's problem (for me very important) with the use function keys - especially to adjust LCD brightness (fn+F6, fn+F7) - they simply doesn't work under XP.
    Have anyone that kind of problem? Mayby it's only the matter of a dedicated program which controls it but unfortunately I've got no idea what program it is.
    I would be grateful for any help.
  8. Tralfamador
    Tralfamador Newbie
    Thanks prightup2 for the resarch and the solution. You saved the day, big time!
    I have a brand new p205-s6267 with a XP Pro SP2 installed. I managed to get all the proper drivers, but the display driver gave me a hard time. I was very-very-very close to return this piece of crap (sorry. it's a company laptop)
    But....thanks to u, i have a working display driver for this Toshiba P205-S6267.
    May Toshiba burn in hell. Thank you :D :D :D
  9. Marton
    Marton Newbie
    Many thanks for this!!! With this info, I was able to install XP with all the drivers on a Vaio VGN-N350FE. Most of the drivers you attached worked (chipset, video, sound, mass storage) I only had to find Wireless/PCI ethernet/Modem drivers myself.
    THANK YOU!!
  10. doodoo
    doodoo Newbie
    Thanks for the drivers!!!
    How did you get the wireless adapter working on the toshiba p205-s6267 with windows xp?
    Thanks!
